Дата выхода 19 сентября 2014 года. Это большая версия iPhone 6 с 5.5-дюймовый экраном.
Weak Wifi or poor Signal
This iPhone only sees near WiFi networks. The more far away the router the more poor signal
I have replaced this antenna:
iPhone 6 Plus 5GHz Wi-Fi Antenna
And no differnece
SHould I try with this?
iPhone 6 Plus Wi-Fi/Bluetooth Antenna
Thank you
Update (09/27/2019)
Hi, no antennas have fixed the problem. It seems to be a hardware issue. I will send to my friend’s lab to see if it can be fixed. I will post the results. Thank you
Replace a torn or missing Wi-Fi antenna compatible with the iPhone 6 Plus model #A1522, A1524, A1593. Fix unreliable connectivity to Wi-Fi service. Изображение
Товар
$23.99
Replace a torn or missing Wi-Fi and Bluetooth Antenna compatible with the iPhone 6 Plus model #A1522, A1524, A1593. Fix unreliable connectivity to Wi-Fi and Bluetooth service. Part #821-00128-A. Изображение
Товар
$22.99
Это хороший вопрос?
Счет 0
Добавить комментарий
2 Ответов
Наиболее полезный ответ
I would like to suggest a cheaper way than replacing a router? But you need jailbreak for this. You can install SignalRefresh Cydia Tweak on your device and boost the signal strength. The tweak is available in Bigboss repository in Cydia apps store. If you feel you need to try this but do not know about jailbreaking will www.cydiacloud.com be useful
Был ли этот ответ полезен?
Счет 1
Hi @macpatagon
Have you tried to update or restore the software? Sometimes weird issues can be caused by third party apps and/or software bugs.
Счет 0
Добавьте свой ответ
Flavio буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 3
За последние 30 дней: 43
За всё время: 208
