Смартфон был выпущен 22 сентября 2017 года в двух модификациях: A1864, A1897, доступный GSM или CDMA модулями. Встроенное хранилище есть на 64 Гб или на 256. iPhone 8 Plus увидел свет в трех оттенках корпуса: золотом, серебристом и Space Gray.
678вопросов Показать все
Can I repair my front microphone?
I stupidly attempted to clear some of the dust from the grill of my microphone with an air gun. The microphone for recording videos works fine but no one can hear me if I try to make a call. Any ideas?
Это хороший вопрос?
Оценка 0
1 Комментарий
Thanks for the advice I will give it a go much appreciated!
из
Добавить комментарий
3 Ответов
Выбранное решение
One of the phone’s mic’s is on the charge port so you could try replacing that and see if it improves your situation. If that doesn’t help you could also try replacing your proximity flex cable, where the other mic is located. I’ll post links to repair guides below, parts needed should also be linked in the guides
Proximity replacement guide
Charge port replacement guide
Hope this helps!
iPhone 8 Plus Lightning Connector Assembly Изображение
Инструкция
iPhone 8 Plus Lightning Connector Assembly Replacement
Сложность:
Модерировать
40 minutes - 2 hours
iPhone 8 Plus Front Camera and Sensor Cable Изображение
Инструкция
iPhone 8 Plus Front Camera and Sensor Cable Replacement
Сложность:
Модерировать
Был ли этот ответ полезен?
Оценка 0
2 Комментариев:
do you have the guides for a regular iPhone 8? people can't hear me on calls, and voice memos don't record. One of the mics does pick up sound when I record video though.
из
Was everything working fine before you attempted to blow things out or was the same thing happening? It could be that you attempt to blow things out actually may have made the problem worse. I would try using a toothpick and toothbrush to clean out the holes manually. If this does not fix the problem, you may need to replace the charge port.
Оценка 0
Hi Carlos, Thanks for responding to my question. I didn’t try to blow any high pressure air on the microphone or charging port. I did pick out some dust and dirt with a paperclip though. I just installed the latest iOS update, and the next day, my mic stopped working. People couldn’t hear me at all on calls, and voice memos don’t record, though on occasion, it the mic will work. As I said before, I can make videos that have clear sound. I did restart and reset the phone. That has not worked. So, changing the charge port is something that I can do that will fix the mic as well? If so, is there a manual on how to do this and a place to order the replacement parts? Thanks a million! Cheers, Paul
Оценка 0
Добавьте свой ответ
Darren Wells будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 5
За последние 7 дней: 20
За последние 30 дней: 100
За всё время: 11,964
