iPhone 8 Plus Front Camera and Sensor Cable Replacement
Выберете то, что вам нужно
  1. iPhone 8 Plus Front Camera and Sensor Cable Replacement, Pentalobe Screws: шаг 1, изображение 1 из 1
    • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 3.5 mm pentalobe screws from the bottom edge of the iPhone.
    • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
    Спросите у FixBot
    Добавить комментарий
  2. iPhone 8 Plus Front Camera and Sensor Cable Replacement, Mark your opening picks: шаг 2, изображение 1 из 3 iPhone 8 Plus Front Camera and Sensor Cable Replacement, Mark your opening picks: шаг 2, изображение 2 из 3 iPhone 8 Plus Front Camera and Sensor Cable Replacement, Mark your opening picks: шаг 2, изображение 3 из 3
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
    Спросите у FixBot
  3. iPhone 8 Plus Front Camera and Sensor Cable Replacement, Tape over any cracks: шаг 3, изображение 1 из 3 iPhone 8 Plus Front Camera and Sensor Cable Replacement, Tape over any cracks: шаг 3, изображение 2 из 3 iPhone 8 Plus Front Camera and Sensor Cable Replacement, Tape over any cracks: шаг 3, изображение 3 из 3
    • If your iPhone has a cracked screen, keep further breakage contained and prevent bodily harm during your repair by taping over the glass.
    • Lay overlapping strips of clear packing tape over the iPhone's screen until the whole face is covered.
    • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
    • If you can't get the suction cup to stick in the next few steps, fold a strong piece of tape (such as duct tape) into a handle and lift the screen with that instead.
    • If all else fails, you can superglue the suction cup to the screen.
    Спросите у FixBot
  4. iPhone 8 Plus Front Camera and Sensor Cable Replacement, Anti-Clamp instructions: шаг 4, изображение 1 из 3 iPhone 8 Plus Front Camera and Sensor Cable Replacement, Anti-Clamp instructions: шаг 4, изображение 2 из 3 iPhone 8 Plus Front Camera and Sensor Cable Replacement, Anti-Clamp instructions: шаг 4, изображение 3 из 3
    Инструмент, используемый на этом этапе:
    Clampy - Anti-Clamp
    $24.95
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your iPhone.
    • Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
    • Squeeze the cups together to apply suction to the desired area.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
    Спросите у FixBot
  5. iPhone 8 Plus Front Camera and Sensor Cable Replacement: шаг 5, изображение 1 из 3 iPhone 8 Plus Front Camera and Sensor Cable Replacement: шаг 5, изображение 2 из 3 iPhone 8 Plus Front Camera and Sensor Cable Replacement: шаг 5, изображение 3 из 3
    • Pull the blue handle forwards to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
    Спросите у FixBot
  6. iPhone 8 Plus Front Camera and Sensor Cable Replacement: шаг 6, изображение 1 из 2 iPhone 8 Plus Front Camera and Sensor Cable Replacement: шаг 6, изображение 2 из 2
    • Heat an iOpener and thread it through the arms of the Anti-Clamp.
    • You can also use a hair dryer, heat gun, or hot plate—but extreme heat can damage the display and/or internal battery, so proceed with care.
    • Fold the iOpener so it lays on the bottom edge of the iPhone.
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • Insert an opening pick under the screen when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle a quarter turn.
    • Don't crank more than a quarter turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next three steps.
    Спросите у FixBot
  7. iPhone 8 Plus Front Camera and Sensor Cable Replacement: шаг 7, изображение 1 из 1
    • The next three steps show how to separate the screen using a suction cup.
    • Heating the lower edge of the iPhone will help soften the adhesive securing the display, making it easier to open.
    • Use a hairdryer or prepare an iOpener and apply it to the lower edge of the iPhone for about 90 seconds in order to soften up the adhesive underneath.
    Спросите у FixBot
  8. iPhone 8 Plus Front Camera and Sensor Cable Replacement: шаг 8, изображение 1 из 2 iPhone 8 Plus Front Camera and Sensor Cable Replacement: шаг 8, изображение 2 из 2
    • Apply a suction cup to the lower half of the front panel, just above the home button.
    • Be sure the suction cup does not overlap with the home button, as this will prevent a seal from forming between the suction cup and front glass.
    Спросите у FixBot
  9. iPhone 8 Plus Front Camera and Sensor Cable Replacement: шаг 9, изображение 1 из 3 iPhone 8 Plus Front Camera and Sensor Cable Replacement: шаг 9, изображение 2 из 3 iPhone 8 Plus Front Camera and Sensor Cable Replacement: шаг 9, изображение 3 из 3
    • Pull up on the suction cup with firm, constant pressure to create a slight gap between the front panel and rear case.
    • Insert an opening pick or other thin pry tool a few millimeters into the gap.
    • The watertight adhesive holding the display in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the screen up and down to weaken the adhesive until you create enough of a gap to insert your tool.
    Спросите у FixBot
  10. iPhone 8 Plus Front Camera and Sensor Cable Replacement: шаг 10, изображение 1 из 3 iPhone 8 Plus Front Camera and Sensor Cable Replacement: шаг 10, изображение 2 из 3 iPhone 8 Plus Front Camera and Sensor Cable Replacement: шаг 10, изображение 3 из 3
    • Slide your pick around the corner and up the left edge of the phone, moving towards the volume control buttons and silent switch, breaking up the adhesive holding the display in place.
    • Stop near the top left corner of the display.
    Спросите у FixBot
  11. iPhone 8 Plus Front Camera and Sensor Cable Replacement, Screen information: шаг 11, изображение 1 из 1
    • There's a delicate cable along the right edge of your iPhone. Don't insert your pick here, as you may damage the cable.
    Спросите у FixBot
  12. iPhone 8 Plus Front Camera and Sensor Cable Replacement: шаг 12, изображение 1 из 3 iPhone 8 Plus Front Camera and Sensor Cable Replacement: шаг 12, изображение 2 из 3 iPhone 8 Plus Front Camera and Sensor Cable Replacement: шаг 12, изображение 3 из 3
    • Re-insert your tool at the lower right corner of the iPhone, and slide it around the corner and up the right side of the phone to separate the adhesive.
    • Don't insert your pick more than 3 mm, as you may damage the display cables.
    Спросите у FixBot
  13. iPhone 8 Plus Front Camera and Sensor Cable Replacement: шаг 13, изображение 1 из 1
    • Gently pull up on the suction cup to lift up the bottom edge of the display.
    • Do not raise the display more than 15º or you'll risk straining or tearing the ribbon cables connecting the display.
    Спросите у FixBot
  14. iPhone 8 Plus Front Camera and Sensor Cable Replacement: шаг 14, изображение 1 из 1
    • Pull on the small nub on the suction cup to remove it from the front panel.
    Спросите у FixBot
  15. iPhone 8 Plus Front Camera and Sensor Cable Replacement: шаг 15, изображение 1 из 3 iPhone 8 Plus Front Camera and Sensor Cable Replacement: шаг 15, изображение 2 из 3 iPhone 8 Plus Front Camera and Sensor Cable Replacement: шаг 15, изображение 3 из 3
    • Slide an opening pick underneath the display along the top edge of the phone to loosen the last of the adhesive.
    Спросите у FixBot
  16. iPhone 8 Plus Front Camera and Sensor Cable Replacement: шаг 16, изображение 1 из 2 iPhone 8 Plus Front Camera and Sensor Cable Replacement: шаг 16, изображение 2 из 2
    • Slide the display assembly slightly down (away from the top edge of the phone) to disengage the clips holding it to the rear case.
    Спросите у FixBot
  17. iPhone 8 Plus Front Camera and Sensor Cable Replacement: шаг 17, изображение 1 из 3 iPhone 8 Plus Front Camera and Sensor Cable Replacement: шаг 17, изображение 2 из 3 iPhone 8 Plus Front Camera and Sensor Cable Replacement: шаг 17, изображение 3 из 3
    • Open the iPhone by swinging the display up from the left side, like the back cover of a book.
    • Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
    • Lean the display against something to keep it propped up while you're working on the phone.
    Спросите у FixBot
  18. iPhone 8 Plus Front Camera and Sensor Cable Replacement, Battery Disconnection: шаг 18, изображение 1 из 2 iPhone 8 Plus Front Camera and Sensor Cable Replacement, Battery Disconnection: шаг 18, изображение 2 из 2
    Magnetic Project Mat
    $19.95
    • Remove four Phillips (JIS) screws securing the lower display cable bracket to the logic board, of the following lengths:
    • Two 1.3 mm screws
    • One 1.4 mm screw
    • One 2.7 mm screw
    • Throughout this guide, keep careful track of your screws so that each one goes back where it came from during reassembly. Installing a screw in the wrong place can cause permanent damage.
    Спросите у FixBot
  19. iPhone 8 Plus Front Camera and Sensor Cable Replacement: шаг 19, изображение 1 из 1
    • Remove the lower display cable bracket.
    Спросите у FixBot
  20. iPhone 8 Plus Front Camera and Sensor Cable Replacement: шаг 20, изображение 1 из 2 iPhone 8 Plus Front Camera and Sensor Cable Replacement: шаг 20, изображение 2 из 2
    • Use the point of a spudger to pry the battery connector up from its socket on the logic board.
    • Bend the connector cable up slightly to prevent it from accidentally making contact with the socket and providing power to the phone during your repair.
    Спросите у FixBot
  21. iPhone 8 Plus Front Camera and Sensor Cable Replacement, Display Assembly: шаг 21, изображение 1 из 2 iPhone 8 Plus Front Camera and Sensor Cable Replacement, Display Assembly: шаг 21, изображение 2 из 2
    • Use the tip of a spudger or a fingernail to disconnect the large lower display connector by prying it straight up from its socket.
    • To re-attach press connectors like this one, press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is even slightly misaligned, the connector can bend, causing permanent damage.
    Спросите у FixBot
  22. iPhone 8 Plus Front Camera and Sensor Cable Replacement: шаг 22, изображение 1 из 2 iPhone 8 Plus Front Camera and Sensor Cable Replacement: шаг 22, изображение 2 из 2
    • Disconnect the second lower display cable connector, directly behind the one you disconnected in the previous step.
    Спросите у FixBot
  23. iPhone 8 Plus Front Camera and Sensor Cable Replacement: шаг 23, изображение 1 из 2 iPhone 8 Plus Front Camera and Sensor Cable Replacement: шаг 23, изображение 2 из 2
    • Remove the two tri-point Y000 screws securing the bracket over the front panel sensor assembly connector:
    • One 1.0 mm screw
    • One 1.2 mm screw
    Спросите у FixBot
  24. iPhone 8 Plus Front Camera and Sensor Cable Replacement: шаг 24, изображение 1 из 1
    • Remove the bracket covering the front panel sensor assembly connector.
    Спросите у FixBot
  25. iPhone 8 Plus Front Camera and Sensor Cable Replacement: шаг 25, изображение 1 из 2 iPhone 8 Plus Front Camera and Sensor Cable Replacement: шаг 25, изображение 2 из 2
    • Use the tip of a spudger or a fingernail to disconnect the front panel sensor assembly connector from its socket.
    Спросите у FixBot
  26. iPhone 8 Plus Front Camera and Sensor Cable Replacement: шаг 26, изображение 1 из 1
    Спросите у FixBot
  27. iPhone 8 Plus Front Camera and Sensor Cable Replacement, Earpiece Speaker: шаг 27, изображение 1 из 1
    • Remove the five Phillips screws securing the earpiece speaker bracket:
    • Two 1.8 mm screws
    • One 2.3 mm screw
    • One 2.4 mm screw
    • One 2.8 mm screw
    Спросите у FixBot
  28. iPhone 8 Plus Front Camera and Sensor Cable Replacement: шаг 28, изображение 1 из 1
    • Remove the earpiece speaker bracket.
    Спросите у FixBot
  29. iPhone 8 Plus Front Camera and Sensor Cable Replacement: шаг 29, изображение 1 из 3 iPhone 8 Plus Front Camera and Sensor Cable Replacement: шаг 29, изображение 2 из 3 iPhone 8 Plus Front Camera and Sensor Cable Replacement: шаг 29, изображение 3 из 3
    • Use the flat end of a spudger to lift the front-facing camera from its housing.
    • Gently bend the camera ribbon cable to the side to clear the way to the earpiece speaker underneath.
    Спросите у FixBot
  30. iPhone 8 Plus Front Camera and Sensor Cable Replacement: шаг 30, изображение 1 из 1
    • Remove the earpiece speaker.
    Спросите у FixBot
  31. iPhone 8 Plus Front Camera and Sensor Cable Replacement, Front Camera and Sensor Cable: шаг 31, изображение 1 из 2 iPhone 8 Plus Front Camera and Sensor Cable Replacement, Front Camera and Sensor Cable: шаг 31, изображение 2 из 2
    • Gently fold the camera and attached ribbon cable toward the bottom of the iPhone to allow access to the components underneath.
    Спросите у FixBot
  32. iPhone 8 Plus Front Camera and Sensor Cable Replacement: шаг 32, изображение 1 из 1
    • Use a hairdryer or heat gun or prepare an iOpener and apply it to the top front of the display for about a minute, in order to soften the adhesive securing the sensors.
    • The sensors in the following steps are fragile. To increase your chances of removing them without damage, repeatedly add more heat as needed. Alternatively, add a drop or two of isopropyl alcohol and let it penetrate under the sensors before you pry them up.
    Спросите у FixBot
  33. iPhone 8 Plus Front Camera and Sensor Cable Replacement: шаг 33, изображение 1 из 2 iPhone 8 Plus Front Camera and Sensor Cable Replacement: шаг 33, изображение 2 из 2
    • Slide a spudger under the ambient light sensor flex cable, and lift the sensor out of its housing.
    Спросите у FixBot
  34. iPhone 8 Plus Front Camera and Sensor Cable Replacement: шаг 34, изображение 1 из 3 iPhone 8 Plus Front Camera and Sensor Cable Replacement: шаг 34, изображение 2 из 3 iPhone 8 Plus Front Camera and Sensor Cable Replacement: шаг 34, изображение 3 из 3
    • Slide the tip of a spudger underneath the proximity sensor flex cable, and lift the sensor out of its housing.
    Спросите у FixBot
  35. iPhone 8 Plus Front Camera and Sensor Cable Replacement: шаг 35, изображение 1 из 3 iPhone 8 Plus Front Camera and Sensor Cable Replacement: шаг 35, изображение 2 из 3 iPhone 8 Plus Front Camera and Sensor Cable Replacement: шаг 35, изображение 3 из 3
    • Insert the sharp edge of an iFixit opening tool underneath the camera assembly's flex cable, on the opposite side from the front-facing camera.
    • Use an iOpener or hair dryer as needed to heat the top portion of the display and soften the adhesive securing the flex cable.
    • Pry up to separate the edge of the flex cable from the back of the display.
    Спросите у FixBot
  36. iPhone 8 Plus Front Camera and Sensor Cable Replacement: шаг 36, изображение 1 из 3 iPhone 8 Plus Front Camera and Sensor Cable Replacement: шаг 36, изображение 2 из 3 iPhone 8 Plus Front Camera and Sensor Cable Replacement: шаг 36, изображение 3 из 3
    • Insert the point of a spudger underneath the same portion of the flex cable that you separated in the previous step.
    • Continue separating the remainder of the flex cable, pushing the spudger underneath the row of circular gold earpiece speaker contacts.
    Спросите у FixBot
  37. iPhone 8 Plus Front Camera and Sensor Cable Replacement: шаг 37, изображение 1 из 3 iPhone 8 Plus Front Camera and Sensor Cable Replacement: шаг 37, изображение 2 из 3 iPhone 8 Plus Front Camera and Sensor Cable Replacement: шаг 37, изображение 3 из 3
    • Remove the front camera and sensor cable assembly.
    • A piece of black double-sided insulating tape lies between the display and three rows of copper contacts on the back of the camera/sensor cable. It may remain stuck to the display, or it may come off with the cable.
    • When reassembling, verify the tape is in place, or else cover the contacts on the back of the cable with an appropriate tape, such as Kapton tape.
    Спросите у FixBot
Заключение
35 человек успешно провели ремонт по этому руководству.
Jeff Suovanen
Участник с: 08/06/13
453 566 Репутация
Автор 259 руководств
Команда
iFixit Участник iFixit
Staff
123 членов
Автор 31 535 руководств
8 Комментарии к руководству
What happens if the camera/ sensor cables come apart but dont tear if ya know what i mean? theres 2 cables and theyre like taped on top of one another and they connect eachother… well, in my case they just came apart..
Devayn “LiveLoveDMND” Diamond - Ответить Поделиться
Just had the same problem. I placed a new flexcable, they're not very expensive.
Davy Thoelen - Ответить Поделиться
what is the tape, or the gold connectors that the tape covers for?
lewis - Ответить Поделиться
Salve,
Ho proceduto alla sostituzione della camera frontale ma, quando accendo il tel il sistema si avvia in modalità loop senza mai avviare il sistema operativo.
Ovviamente se non collego il flat della camera frontale il telefono si avvia regolarmente. Ho anche provato con una camera frontale nuova senza risultato.
Potreste aiutarmi?
maurizio.r - Ответить Поделиться
I removed one of the 2 small circular stickers (one is white, one green) from where the sensor gets placed. Is it a problem?
alberto pias - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 5
За последние 7 дней: 46
За последние 30 дней: 240
За всё время: 72,950
