FLIR Thermal Imaging broken lightning connection
I have a FLIROne Pro for IOS that attaches to the iPhone for thermal image photos. The lightning connection broke off can this be repaired ?
Это хороший вопрос?
The FLIR ONE is available in three generations and is limited to 9 frames per second. The cameras can be used to detect things like air and water leaks. The second-generation model has increased resolution over the first-generation model and is supported by nearly every smartphone.
@beemom take a look on here How to fix a dead FLIR ONE and see if yours opens up in a similar manner. If so that would be the way to get to the board and the connector. Problem will be to find a replacement. “Apple Lightning Connectors” are available at places like Alibaba.com and others but due to their size etc. some good soldering skills will be required. We would need to see more of the board and how the connector is attached. You may also consider using a connector from a lightning cable or even create cable connection instead of a direct connection. FLIR does not repair their devices if they are not covered under warranty. They will only replace.
Инструкция
Сложность:
Очень просто
2 - 5 minutes
Инструкция
Сложность:
Просто
10 minutes
Lightning connectors usually just desolder themselves—-you can probably fix it with a soldering iron, solder, flux, and some epoxy, then use a flexible lightning extender to attach the camera to the phone in the future.
Комментарии:
Is this something you have been successful with? Do you know of any videos available?
из Susan
well sure I have had success--but I'm a professional microsolderer. I would try to see how I could split the housing in half. If you can't find how it originally came together then you could dremel it. Once you can see the lightning connector and the board, then post a picture and we can let you know if it looks repairable.
из jessabethany
I broke the connector and I was able to replace and solder another connector which I recovered from a cable. The connections seem ok, I’ve checked and measured them one by one, but the phone does not recognise the camera. Did anyone else experienced this?
Комментарии:
hi i have the same issue, broken connector due to a drop. i tried with another genuine apple usb cable connector and it doesnt recognize the camera even if it boots and seems to run/charge perfectly. did u manage to fix it somehow?
из Cosmin RI
Bummer!
So now the question is can you find another broken one on eBay which has a good connector assembly and can you swap the part out?
Sounds like you’re half way to a guide here ;-} If you take on the challenge you can help others! By taking notes and pictures as you figure it out and post your discovery here! https://www.ifixit.com/Contribute
It’s people like you that help us chip away! Help support the Right to Repair!
Ive same issue. Though I took it apart and found it’s a simple push on connection within the unit. 4 screws and it was apart and now attempting to contact flir
За последние 24часов: 1
За последние 7 дней: 10
За последние 30 дней: 56
За всё время: 514
It should be! Did you reach out and talk with company to see what they say?
I doubt anyone has tried fixing one as its a very limited market.
из Dan
Hi Dan, yes I did. They said physical damage isn’t covered under warranty and offered me a half price coupon to buy another. It seems they don’t fix them only replace them.
из Susan
