Руководство по ремонту и диагностике неисправностей планшета RCA Voyager III — 7-дюймового бюджетного планшета, работающего на ОС Android 6.0 с доступом к магазину приложений Google Play.
My battery won't charge.
My tablet was stuck in fastboot mode. Now it won't charge. When it's plugged in the battery icon with the lightning bolt shows but it doesn't move. The screen flashes on and off. Holding the power and volume buttons only makes the screen flash. It doesn't bring up recovery mode. I've tried unplugging the battery but it doesn't change anything. Can anyone help?
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
laurie  check your USB post as well as your charger to make sure that all of those are working okay. I’d start with a new battery since part of this can be caused by a bad battery and if nothing else it will give you a known-well starting point for further troubleshooting.
Был ли этот ответ полезен?
Счет 0
1 Комментарий:
Thank you for your response.
из
Добавьте свой ответ
laurie буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 3
За последние 30 дней: 6
За всё время: 295
