Gopro wet - Salt water
Hello!
I had a recently accident in Bali with my gopro hero 4 black.
Yesterday i went to dive and the dive case was not fully closed perhaps because the white rubber around the back case was damaged and salty water came through it. Besides, i didn't put the lateral black plastic cap over the ports (Charge&SD) so i think the water went through the camera easier.
I did realize when i was at 30 meters, so i couldn't do anything to stop the water coming in until we finished the dive.
Well, after diving when i arrived to the bungalow. I put the camera in sweet water trying to remove the salt. After that, i went to buy some rice to put it inside around 1 day and half.
Right now, i am able to switch on the camera. The front lcd works well and also the front button. The shutter button and the lateral wifi doesn't respond.
The charger port and Micro SD doesn't work. I connected an external LCD Bacpac and the screen is fully black so I think the camera doesn't work properly neither.
I would like to repair it as far as i can.
Do you think would be possible to fix it?
Which spare parts do you think i need to change?
I really appreciate your help!
Thank you so much
Это хороший вопрос?
