Hi,
What is the model number of the laptop?
Try the following:
Start the laptop and when it boots into Windows, force stop the laptop by holding the Power button until it shuts down.
Do this 3 times in a row, i.e. start > boot > force shutdown > start > boot > force shutdown etc.
On the 3rd attempt it should boot into the Windows Recovery Environment menu area.
Once there select Reset this PC and select the option you want and follow the prompts.
If you can’t get into the WRE menus this way or it doesn’t work either, try using a recovery USB disc.
The recovery USB disc can be created from any known working Win 10 PC. (try another PC not yours)
All you need is a 8GB USB flashdrive and about an hour of your time.
In the host PC go to Control Panel > Recovery > Create a Recovery drive and follow the prompts.
Once you have the USB drive insert it into your laptop and start the laptop. You’ll need to change the boot order in BIOS to boot from the USB as the first option (press F10 after it starts but before it boots into Windows - I think).
If you cannot boot from the USB you’ll need to get into BIOS (press F2 after it starts but before it boots into Windows - I think) and enable Legacy USB or CSM whichever option you have. Save the changes and restart the laptop.
The laptop should boot from the USB and show the same WRE menu options as mentioned above.
Был ли этот ответ полезен?
Проголосовали
Отменить
Оценка
3
Отмена
Scroll through this thread to find the appropriate place for this comment. Then, click "Attach comment to this post" to move it.
2 Комментариев
Whats the error code?
из NR26
Hey Can you please show us the problem code?
из Mark Blendy
