Why is my keyboard inputting multiple letters?
So i've been having this problem where if I push Shift + any key it repeats that key and i'm not sure why. Sticky keys, and repeated keys are turned off so i'm unsure of what the problem is.
The keyboard is fairly new, about one month (almost two) old, haven't spilled anything on the keys either.
This issue has only occured today and i've attempted multiple things like uninstalling/updating the keyboard drivers, restarting my pc, and changing the usb slot the keyboard is plugged into.
Here's an example of what I mean: https://i.imgur.com/DSdcSHS.gifv
Also, I would like to mention this doesn’t happen normally when typing, it only occurs when I push shift + any key, ctrl + any key, alt + any key, and apparently holding tab acts as if i’m spamming it multiple times.
Это хороший вопрос?
2 Комментариев
HI, ,
Your link is not working. At leastnot inmyPC.
Here's how to add images in ifixit
Adding images to an existing question.
Try using a USB keyboard, plugged into the computer, to check if the problem is with the keyboard or the computer.
из jayeff
It's an issue with the keyboard apparently, i've tried another keyboard and it doesn't have the same issue. I'm not sure if there's an option to make it do that with like shortcut keys or something. It's a blackweb centaur btw :P
из Zorro
