2.2 GHz (Turbo Boost up to 3.4 GHz), 2.5 GHz (Turbo Boost up to 3.7 GHz), or 2.8 GHz (Turbo Boost up to 4.0 GHz) quad-core Intel Core i7 processor with 6 MB shared L3 cache.
774вопросов Показать все
A question about compatibility between models
I have a 2015 Macbook pro with upper-end i7, full memory, and a good display adapter. Recently some liquid was spilled into the keyboard and now things are beginning to quit, like one of the USB ports for example. The display also has a crack in it. I was wondering if the memory, processor, or display adapter would be compatible with newer MBPro’s? I was thinking about buying a newer model and then upgrading it.
Thanks!
-BW
Update (12/13/2019)
Dan,
Sorry for this late reply. I have health concerns to deal with. Can you still assist me in finding a replacement display? I have a MacBook Pro (Retina, 15-inch, Mid 2015).
Here are the full specs...
Model Name: MacBook Pro
Model Identifier: MacBookPro11,5
Processor Name: Intel Core i7
Processor Speed: 2.8 GHz
Number of Processors: 1
Total Number of Cores: 4
L2 Cache (per Core): 256 KB
L3 Cache: 6 MB
Hyper-Threading Technology: Enabled
Memory: 16 GB
Boot ROM Version: 194.0.0.0.0
SMC Version (system): 2.30f2
Serial Number (system): C02QW0WFG8WQ
Thanks!
- Bill
Это хороший вопрос?
Оценка 0
3 Комментариев
It seems you picked the wrong reference model, as the Macbook A1534 you chose doesn’t have an i7 processor, nor “ports”, it’s got an Intel M Cpu and a single Usb-C port. However, if you have as I believe a 2015 Macbook Pro 13” , not a single part is compatible with following models, Cpu and Ram are soldered on the logic board, Ssd is different, screen is different, even the charger is different.
из
Thanks, arbaman. Of course, you are correct. It is an A1398. I had not looked before sending the request. My bad!
из
@Bill Wilson Not a problem at all. Unfortunately same thing goes with the big guy A1398 too, everything is soldered on the board.
из
Добавить комментарий
1 ответ
Наиболее полезный ответ
Here’s the guide MacBook Pro 15" Retina Display Mid 2015 Display Assembly Replacement. And here’s one source for the needed part: Retina MacBook Pro 15" Complete Display (used) Apple P/N 661-02532
Был ли этот ответ полезен?
Оценка 2
2 Комментариев:
Dan, thanks for the info. It will come in handy. The display you suggested was sold out. Do you have any others you would recommend?
Thanks
- Bill
из
@Bill Wilson - They also sell New as well as lower grade display Grade-B
из
Добавьте свой ответ
Bill Wilson будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 80
