Guides and repair information for assorted graphics cards, also known as video cards, graphics adapters, or display adapters.
111вопросов Показать все
I sheared a resistor(?) off of the back of my 1060, can it be fixed?
I have a Zotac gtx 1060 6 gb, and while i was swapping to a new case, i managed to knock a little black retangle, what i believe is a resistor, off of the card. Can it be fixed, or do i need to look for a replacement?
Это хороший вопрос?
Оценка 0
3 Комментариев
Suggest post a pic of the damaged board/component. Can you solder and is there room? If not, you’ll need to get new. Good luck!
из
alex collins just like the aforementioned, post some pictures of what you got going on. Post it with your QUESTION
Adding images to an existing question
из
@oldturkey03 i have put a picture up, thanks for the heads up
из
Добавить комментарий
2 Ответов
Выбранное решение
alex collins looks like reference designator C6(8?)42 is the part. That is a capacitor not a resistor. Yo ugot plenty of room to solder and the solder pads look really good as well. Since there are no markings on the capacitor you will need a capacitance tester (some multimeter have it standard) and measure the capacitor to get a replacement. Most likely mouser.com or digikey.com would have it. If you do not have a capacitance meter try to get somebody that does repairs to check it for you. Electronics stores , Colleges, Trade Schools etc. will also be an option. If you cannot measure that cap measure the one in location C764. On a hunch, I bet they are the same value. Not a difficult job to fix this board.
Был ли этот ответ полезен?
Оценка 4
Send a pic so i can find a replacement for you. Also you need to solder it back on! So when you go to the hardware store always get Rosin core solder With flux if possible. I also recommend you get 60/40 type that contains lead . and also you if you need to know how to solder try this video series.
https://www.youtube.com/watch?v=vIT4ra6M...
If possible buy a solder iron that has Temp Control + a grounding pin on the plug.
NOTE: Try buying a mask as soldering is toxic. But if your brave you can just hold your breath and be quick!
Оценка 0
Добавьте свой ответ
alex collins будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 3
За всё время: 349
