Ice maker won't fill with water
I just replaced my water supply line between the control valve and water filter on my Kenmore Elite refrigerator. I have good pressure and can dispense water with no problem. However, no water is dispensing to the ice maker. It worked fine before replacing the water line, and the ice maker is turned on. What could the problem be?
Это хороший вопрос?
Счет 1
1 Комментарий
Hi,
What is the model number of the refrigerator?
из
Добавить комментарий
1 ответ
Выбранное решение
Here are some situations that can cause no water to ice maker. Starting with the most common.
A wire came off the water inlet valve.
A failed water inlet valve.
The ice maker is turned off
Tempature at ice maker isn’t below 9*f
Air in the water line
The ice maker hasn’t had enough time to cycle
A problem in the ice maker
The water line to ice maker froze.
Был ли этот ответ полезен?
Счет 2
3 Комментариев:
The light does not light when the ice maker is on position and cannot change size of cubes, but will dispense water.
из
Is there a different motor that runs the ice maker?
из
@barbararod54488
What is the
из
Добавьте свой ответ
Mark T. буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 7
За последние 30 дней: 33
За всё время: 7,434
