ΠŸΠ΅Ρ€Π΅ΠΉΡ‚ΠΈ ΠΊ основному ΡΠΎΠ΄Π΅Ρ€ΠΆΠ°Π½ΠΈΡŽ
ΠŸΡ€ΠΈΡΠΎΠ΅Π΄ΠΈΠ½ΡΠΉΡΡ ΠΊ сообщСству Ρ€Π΅ΠΌΠΎΠ½Ρ‚Π½ΠΈΠΊΠΎΠ² - Π‘ΠΎΠ·Π΄Π°ΠΉ Π°ΠΊΠΊΠ°ΡƒΠ½Ρ‚
ШСстоС ΠΏΠΎΠΊΠΎΠ»Π΅Π½ΠΈΠ΅ Maxima с ΠΊΠΎΠ΄ΠΎΠ²Ρ‹ΠΌ ΠΎΠ±ΠΎΠ·Π½Π°Ρ‡Π΅Π½ΠΈΠ΅ΠΌ A34 ΠΏΡ€ΠΎΠ΄Π°Π²Π°Π»ΠΎΡΡŒ Ρ‚ΠΎΠ»ΡŒΠΊΠΎ Π² БША, КанадС ΠΈ МСксикС. БСрийная модСль Π±Ρ‹Π»Π° прСдставлСна Π² 2003 Π³ΠΎΠ΄Ρƒ Π½Π° БСвСроамСриканском ΠΌΠ΅ΠΆΠ΄ΡƒΠ½Π°Ρ€ΠΎΠ΄Π½ΠΎΠΌ автосалонС ΠΊΠ°ΠΊ Π°Π²Ρ‚ΠΎΠΌΠΎΠ±ΠΈΠ»ΡŒ 2004 модСльного Π³ΠΎΠ΄Π°.
Car won't start or crank
  • All fuses where pulled when I put them back in car won't start hear a click behind fuse panel in the blue looking relays I guess they are called, car started fine before interior fuses where pulled and put back in
  • Thanks
ΠžΡ‚Π²Π΅Ρ‚ Π½Π° этот вопрос Π£ мСня Ρ‚Π° ΠΆΠ΅ ΠΏΡ€ΠΎΠ±Π»Π΅ΠΌΠ°
Π­Ρ‚ΠΎ Ρ…ΠΎΡ€ΠΎΡˆΠΈΠΉ вопрос?
Π‘Ρ‡Π΅Ρ‚ 0
Π”ΠΎΠ±Π°Π²ΠΈΡ‚ΡŒ ΠΊΠΎΠΌΠΌΠ΅Π½Ρ‚Π°Ρ€ΠΈΠΉ
2 ΠžΡ‚Π²Π΅Ρ‚ΠΎΠ²
НаиболСС ΠΏΠΎΠ»Π΅Π·Π½Ρ‹ΠΉ ΠΎΡ‚Π²Π΅Ρ‚
Check the relays that are ignition / starting related and fuses nearby. Clicking makes me think a relay coil is pulling in but perhaps the contacts aren’t plugged down (relay is not all the way engaged (pressed) into its socket) or an associated fuse is not pressed down. Basically pull them out again and carefully reseat each one back into its socket.
Π‘Ρ‹Π» Π»ΠΈ этот ΠΎΡ‚Π²Π΅Ρ‚ ΠΏΠΎΠ»Π΅Π·Π΅Π½?
Π‘Ρ‡Π΅Ρ‚ 1
A simple β€œturn off and turn on again” system should work here. Try pulling out the interior fuses and putting them back into place, making sure they attach properly.
Π‘Ρ‡Π΅Ρ‚ 0
Π”ΠΎΠ±Π°Π²ΡŒΡ‚Π΅ свой ΠΎΡ‚Π²Π΅Ρ‚
James Birkes Π±ΡƒΠ΄Ρƒ Π²Π΅Ρ‡Π½ΠΎ Π±Π»Π°Π³ΠΎΠ΄Π°Ρ€Π΅Π½.
Бтатистика просмотров:
Π—Π° послСдниС 24 часов: 0
Π—Π° послСдниС 7 Π΄Π½Π΅ΠΉ: 4
Π—Π° послСдниС 30 Π΄Π½Π΅ΠΉ: 32
Π—Π° всС врСмя: 996
