1.25 in spring strap fell out after repair.
This is a spring with 2 small mounting holes with a slotted end.
Это хороший вопрос?
Это хороший вопрос?
Hi @sandy430 ,
Without an image it will be difficult to identify it and where it belongs, if indeed it does belong in the laptop.
Here’s a link to the hardware maintenance manual for the laptop.
It doesn’t mention or show the spring in the parts section as a separate part so maybe you’re right and it doesn’t belong in there.
Был ли этот ответ полезен?
За последние 24часов: 0
За последние 7 дней: 4
За последние 30 дней: 6
За всё время: 55
6 Комментариев
Hi @sandy430 ,
The make and model number of the tablet would go a long way to getting a helpful answer
Adding an image of the spring to the question would also help.
Here's how.
Adding images to an existing question
из jayeff
I added a second HD. The unit seems to work ok
из John Iwaniec
Lenovo Flex5-1570
из John Iwaniec
No picture. the two mounting holes appear to from a pressed mounting. It has sight hump with the slot at the other end.
из John Iwaniec
I found it on the work table with the reassembly. May be from something else. Sorry
из John Iwaniec
Показать 1 больше комментариев
