Hi @pamy ,
As you know water, and electronics and electricity are not a good mix.
The impurities in the water causes corrosion and provides circuit paths for the electricity which were not in the phone's operating design and could damage the components.
The corrosion is ongoing and doesn’t stop until it has been cleaned away.
First do not turn on your phone and then you need to remove the battery as soon as possible from the phone to minimize any further damage.
Then you need to dis-assemble the rest of the phone and clean all the affected parts using Isopropyl Alcohol 99%+ (available at electronics parts stores) to remove all traces of corrosion and water. Do not use "rubbing alcohol" as in some cases this is only 70% IPA or less, can contain scents or other additives and is not as effective. If you do use it, check the label to verify the amount of IPA. The higher the percentage of IPA the better
Here is a link that describes the process.
Electronics Water Damage
As always with electronics, especially surface mounted PCBs be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board.
Hopefully after you have done all this the phone might possibly work correctly again.
Here’s a link to the ifixit Huawei P10 repair guides which may be of some help.
The microphone is mounted on the USB charge board. If it is determined that the microphone itself is faulty, replacement parts are available online. Just search for Huawei P10 USB charging dock mic board to get results for suppliers of the part.
If this process seems too daunting, take your phone to a reputable, professional phone repair service, experienced in liquid damage repair and ask for a quote for a repair. If you decide to do this, do it sooner than later.
Был ли этот ответ полезен?
Проголосовали
Отменить
Оценка
Отмена
Scroll through this thread to find the appropriate place for this comment. Then, click "Attach comment to this post" to move it.
