GE Profile Micro Crazy
GE PEB9159SJ1SS, 2016, turntable was working, food heating. Now turntable spins, no heating, then turntable doesn’t spin , sometimes food heats. Lately the only constant is if turntable does not spin food does not heat. Right now nothing works, turntable, heating, convection, broil. All the touch pad buttons working.
Это хороший вопрос?
Счет 1
Добавить комментарий
1 ответ
Hi @stavroula ,
Check if the door interlock switches and latch -part#20, 21, 22 & 24 are OK and working. They may have worked loose or the latch is bent/broken and are not operating/releasing when the door is closed.
Be safety aware when working in a microwave oven as they can still be extremely dangerous to work on even if the power has been disconnected. The HV capacitor need to be discharged correctly before working in a microwave
Ensures the microwave operates only when the door is securely closed by detecting the door's position. Изображение
Товар
GE Microwave Door Interlock Switch - WB24X10146
$46.99
Detects and responds to specific commands within the microwave system. Изображение
Товар
GE Microswitch Monitor - WB24X10190
$48.99
Supports the door switches in your microwave to ensure correct function. Изображение
Товар
GE Microwave Door Interlock Switch Bracket - WB14X10049
$43.99
Engages and disengages the microwave door mechanism through a lever action. Изображение
Товар
GE Lever Switch - WB10X27080
$36.99
Был ли этот ответ полезен?
Счет 0
2 Комментариев:
Door, all latches working correctly.
из
@stavroula ,
Juts being pedantic, but did you test the switches with an Ohmmeter to prove that they were operated (and released - one is NO and the other is NC type switch) when the door is closed or just prove that the latches moved the switch(s) actuator?
из
Добавьте свой ответ
Edward Vozzella буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 4
За последние 30 дней: 6
За всё время: 141
