Выпущен 16 сентября 2016 года. Модель 1660, 1778. Стандарты связи GSM или CDMA. Память 32, 128 или 256 ГБ. Цвета: розовое золото, золотой, серебристый, черный и глянцевый черный.
2264вопросов Показать все
What is a normal percentage for an iPhone battery to drop while off?
So we have a large inventory of iphones and ipads. On occasion we will have several that sit on a shelf, fully charged, turned completely OFF, waiting to be deployed. It’s pretty standard to see about half of those devices to lose a significant amount of charge or be completely dead when they are pulled off the shelf to be used.
What is normal? Doing a search online we’ve found a claim of 5% per month, but we are seeing larger numbers than this, or a completely drained battery. We’re talking 1-3 months of sitting on a shelf powered OFF.
When tested on 3u or in the battery health section in iOS settings the claimed number on the battery capacity will always say it’s at an acceptable range. We typically change batteries at 88% or lower.
Anyone have experience with this?
Это хороший вопрос?
Оценка 0
1 Комментарий:
i guess im looking for input from folks that deal with a large number of devices that would have experienced this, like us.
Corporate repair depots and such, or any shop or store that has a back stock that would have seen this before.
из
Добавить комментарий
1 ответ
As far as I know, typically when battery health drops below 86% is when people start to notice battery issues. I would just take them out and charge them every so often.
Был ли этот ответ полезен?
Оценка 0
1 Комментарий:
Well as stated we will change a battery if it falls below 88% health. We have seen this power drop on phones that indicated 100% battery health, so im looking for what the consensus on what is normal. As I said, if you do a google search you will find claims of 5% being normal for the battery to deplete, but no definitive answer. Folks at corporate repair depots or anyone dealing with large numbers of devices might have seen this if they have ever had to sit on stock for a while
из
Добавьте свой ответ
Chris k будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 100
