My computer won't recognize my iPod Mini
I plugged my iPod Mini into my computer, and it showed the screen where it says do not disconnect without ejecting. iTunes didn’t recognize the device, and it didn’t appear as a hard drive under windows file explorer. About 30 seconds later, it showed the folder with the exclamation point. Every 30 seconds it cycles between the two screens. I thought it might be a hard drive problem, so I replaced the drive with an adapter to a micro sd and an empty micro sd, and have the same results. No matter which drive is installed, it shows the folder with the exclamation point when turned on and not plugged into a computer. What is wrong with it and how do I fix it?
Это хороший вопрос?
Счет 0
Добавить комментарий
