Does anyone know how to fix this?
Hi! Does anyone know how to fix this lamp? It has three sockets inside and is touch sensitive. You can touch it up to three times to turn each bulb on. I’m not sure if I accidentally put 60 watt bulbs in instead of 40 watts and burnt it out. It just won’t turn on anymore.
Here is the URL with the specs: https://www.officedepot.com/a/products/7...
Это хороший вопрос?
2 Комментариев
Once fixed, use LED bulb. Low wattage same light.
из mike
FYI: if the touch lamp is the dimming type, need to ensure you get DIMMABLE LED lamps. It sounds like the particular lamp might be an unusual design, that turns each of the 3 lamps on, to have 1, 2 or 3 on, then all off. If so, then NON-Dimmable ones MIGHT work OK.
из Tony Davis
