Представленный 3-его марта 20 17 г. Nintendo Switch- это портативная приставка, способная устанавливаться в док-станцию и выводить картинку на TV
Horizontal lines, and black screen with sound
Recently my Switches screen started acting up out of nowhere. When I power it on or wake it the screen is covered in multicolored horizontal lines with a sort of grid pattern, after about 1-3 seconds the screen will go black with backlighting still present. The digitizer seems to work perfectly as well, and the Switch functions normally when docked. This problem seems to have appeared out of the blue with no forewarning. It seems to have occurred in the span of about 5-10 minutes. I plugged my switch into the charger and left the room for a moment, upon returning the screen was completely covered in the aforementioned lines. I’m not sure if it’s an issue with the lcd or possibly an issue with the motherboard. I opened the switch up and there doesn’t seem to be any issue with the ribbon cables or connection. Any help would be very very much appreciated.
Это хороший вопрос?
Счет 4
4 Комментариев
I have same issue on my switch lite
из
Hello did you solve your problem with the switch screen? I'm having the same issue with my switch lite and it came out if nowhere.
из
Same just happened to me yesterday without me dropping it or anything happened out of the blue just like that
из
I have this exact same problem, it came out of nowhere while someone was playing on it today. The screen also seems pixelated in some way, I'm gonna try to do something with the LCD flex cable.
из
Добавить комментарий
4 Ответов
Выбранное решение
I reseated the LCD flex cable for the display carefully and that seemed to fix the problem for me. It only occured when I unplugged the display cable from a previous repair.
If reseating the display connector does not help the display most likely needs to be replaced:
Nintendo Switch LCD Replacement
Nintendo Switch LCD
Replace a damaged or malfunctioning LCD display panel in a Nintendo Switch. Изображение
Товар
Nintendo Switch LCD
$49.99
Был ли этот ответ полезен?
Счет 2
2 Комментариев:
Thanks for the advice I’ll give it a shot, not sure how the cable could have been dislodged, possibly overheating?
из
The cable shouldn't go loose by itself as it is locked into place with a zif-flap connector. Worst case it would be the screen going faulty and needing to be replaced.
из
All i know, i lived in jamaica and my switch have lines, and i don't know how to fix it, All i gotta say is goodbye switch, my aunt gave me this nintendo from another country, bye nintendo, bye youtube, bye fortnite😞
Счет 1
my switch lite have that issue. when some ants get inside of my switch lite.i think the ants the to eat the ribbon. thats why im getting that issue.
Счет 0
This problem happened to me suddenly mid gaming and seems to get worse the warmer the console gets. I wonder how could this happen.
Счет 0
Добавьте свой ответ
Laurence Zeffler буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 21
За последние 7 дней: 233
За последние 30 дней: 1,224
За всё время: 45,283
