Apple's March 2019 refresh of its iPad Air tablet, sporting an A12 Bionic processor and a 10.5" screen.
Screen White Pressure Point
Ive been seeing this white spot on my screen, and the reps at Best Buy said it was a pressure point on the screen. I tried using a small vacuum pump to try and pull the screen back up from that spot, but it hasn’t fixed it.
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Best Buy Geek Squad really doesn’t know much about repair other than selling a solution. That white spot could be a couple things like a pressure point if the frame was bent or the battery swelling, although that doesn’t seem likely as that tablet came out just last year. It could also be a defective LCD.
Был ли этот ответ полезен?
Счет 0
2 Комментариев:
Any thoughts on how I could possibly fix it? Everything else works fine. Just that the spot itself is right there in my line of sight and what I’ve tried so far doesn’t work
из
@ibsinrg you'll have to take it apart to find out what's wrong with it before you can fix it. I would start by taking the screen off but be very careful. The glass is fused to the LCD, so if you damage the glass or LCD, you'll need to buy a whole new screen assembly. Follow the ifixit guides to take it apart.
из
Добавьте свой ответ
Russell буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 6
За последние 30 дней: 16
За всё время: 1,473
