Accidently sprayed Bug Liquid in Radio
I have a insignia NS-BBBT20 bluetooth radio and i accidently sprayed bug liquid in the hole where the cd goes does my radio have to dryout till tommorrow?
Это хороший вопрос?
Это хороший вопрос?
Hi @gregy108 ,
Do not turn on the radio and then disconnect the power (and also remove the batteries if installed) to minimize any potential problems from occurring.
The spray may leave a conductive residue (I don’t know if it will or not but play it safe) so the radio will have to be disassembled and the spray residue needs to be cleaned away using Isopropyl Alcohol 99%+ (available at electronics parts stores). Also if it is coating the laser lens this will prevent the CD’s from being read properly when they’re inserted, so it will have to be gently cleaned as well.
Here’s the ifixit Electronics Water Damage guide that shows what liquids can do to electronics and what to do when it has.
Unfortunately I couldn’t find a teardown guide for the radio online but here’s a video that shows the internal components so at least you have an idea what it may look like inside.
Also the ifixit Insignia NS-BCDCAS1 guide may help as well
Hopefully a start
Был ли этот ответ полезен?
За последние 24часов: 1
За последние 7 дней: 2
За последние 30 дней: 11
За всё время: 51
