Samsung Xpress M2825ND stopped after blackout
Hi everyone, I have a Samsung Xpress M2825ND printer that stopped working after several blackouts. In particular, when I connect it to the mains and go to press the ON button, it does not make the classic heating noise of the fuser but turns on all the LEDs on the control panel. It appears that the printer is in protection. To turn it off, I have to unplug it from the mains.
Searching the internet I noticed that this printer has produced the same problem for many other people as well, but I could not find a solution.
Do any of you have experiences on this?
I have not yet proceeded to disassemble and test the circuit. In case I should proceed, what do you advise me to check?
Thank you.
Это хороший вопрос?
1 Комментарий
hola a todos, tengo el mismo problema con mi impresora, esta bloqueada y enciende todos los leds del panel de control, si alguien sabe como desbloquear mucho sabría agradecer
из LUIS DIAZ
