Problems with screen after long time not using
Had it lying around for about 1~2 years. After charging up and open back the screen turns into some water-ish damage almost entire screen while the edges still looked normal.
Is the screen panel damaged? Or is it some steam trapped between screen panel and glass panel?
Это хороший вопрос?
1 Комментарий
You'll need to plug in an external monitor to be sure you don't have anything deeper.
If you are able to get it going enough I would also check your battery as it likely needs replacing, install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see Adding images to an existing question
из Dan
