Released in early 2008, production stopped in December 2009. Lamp used: TLPLV10.
1вопросов Показать все
Will this projector work with a Toshiba Satellite S55-C5274 computer?
I got an adapter for the projector to hook to the computer, I tried both a USB and a HDMI adapter but still can’t get the computer screen to show on the projector screen.
Wondering if the projector is just too old.
Это хороший вопрос?
Оценка 0
2 Комментариев
have you tried checking your computer's settings?
из
@hootonberg Yes, and both my brothers have tried. Thank you.
из
Добавить комментарий
1 ответ
Выбранное решение
This projector looks like it has only a VGA input which will require that you have an adapter that converts the signal from HDMI to VGA. I have used this technique many times for other projectors without fail. You must split the audio from the HDMI if you need to send that elsewhere as well.
Был ли этот ответ полезен?
Оценка 1
2 Комментариев:
I have an adapter that goes from the VGA projector to the HDMI computer (that didn't work). Is there another adapter that converts the signal from HDMI to VGA?
[Audio not necessary]
из
You need an adapter that specifically converts from HDMI to VGA. I have a couple of these and they work just fine.
из
Добавьте свой ответ
Myrna Ann будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 3
За последние 30 дней: 3
За всё время: 140
