Overheating MacBook 12 inch early 2015 after few minutes
Hello,
I have a macbook 12 inch (A1534, 1.2 GHz)
that after about 10 minutes of normal using the zone around the power button (the right side of the speaker, under the LCD) get hot and the system send notifications about the temperature; 1st) the performance may reduced 2nd) the macbook may sleep to cool down.
My laptop is aged but I just used it in trips.
- I put it on a flat table, …
- Already reset SMC, … didn’t help,
- Battery situation: Service recommended,
- Sophos Scan can’t find any virus,
- As I remember It worked well before Catalina, after Big Sur it works very slow (However I think the heating is not related to OS)
- Have about 170/500 GB free space.
- When I still could runs apple diagnosis, I used it but it didn’t find any problem!
- Any help would be highly appreciated.
Это хороший вопрос?
You'll need to install a good thermal monitoring app like TG Pro so you can figure out which sensor is getting toasty. Post a snapshot of the main window so we can see the all of the sensors (you may need to adjust the window size a bit to get all of them int one snapshot) Adding images to an existing question
из Dan
@danj Thank you for replying. I got a picture of the app after the second warn.
Most of sections run between 40-50 C.
из Mac12
I don't see any thermal issues here. I think you'll need to visit an Apple Store to have them look at it.
из Dan
Another problem is my Mac is too slow. even to empty the trash!
из Mac12
