Power button is not working
So the power button on my Macbook A1502 13' mid 2014 does not work. The thing is it does boot as soon as I plug the magsafe in. If it is running the top row of keys do not work, except for esc. Allother keys are working fine.I tried to sort out if it is a logicboard or keyboard problem by shortening the power pads on the logicboard and nothing happened. So I guess its a logicboard issue. Can anyone give me some advice on how to proceed any further?
Update (01/24/2021)
I hope this is the correct screenshot.
https://i.imgur.com/zXa8Slc.png
Had to reinstall MacOS and update it to the newest one, so it took me some time. Now the keys are working again except the power button.
Это хороший вопрос?
2 Комментариев
Given the systems age I would check the battery, install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see Adding images to an existing question
из Dan
You clearly don't use your system much on battery or don't let the battery run down as you've only have 178 cycles. While that's low the age of the battery is getting up there so while thats not your issue today it will likely become one soon.
из Dan
