Руководство по ремонту 28-дюймового LED-телевизора, произведенного компанией Curtis International под брендом RCA, с номером модели RT2806.
TV won't turn on
So my model number is actually rled4627a
And it won't turn on upon plugging it in after waiting some time ill get the red light that there's power
When I try to turn it on I get the green light then immediate power down. No red light unless I unplug and wait 10 mins
Now before it just wouldn't turn on for the past 4 months or so upon start up it would turn of and on about 4-5 times before powering up.
I've removed the back panel to check the power supply im equipped with a multi meter but totally lost wonder how to check the capicotors and maybe sodder a new on in any help would be great repair shop wants 90 dollars for diagnostic a new tv at Walmart is like 260 anyway
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
I would start measuring components on the power supply board (yellow). It might just be the angle from which you took the photo but I would start with diode (D15), an the bigger 330uF 25V capacitor above L2 which appears to be bulging slightly. As it is not fully bulged yet, it may cause your intermittent workings of your TV.
Should everything work as it should, I would measure if you get a stable 24V on the connector above CF1.
If the tv works intermittently, it is often harder to diagnose than a completely dead device.
Был ли этот ответ полезен?
Счет 1
Добавьте свой ответ
archie-comics буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 4
За последние 7 дней: 5
За последние 30 дней: 14
За всё время: 333
