The Bose SoundLink Color is a Bluetooth speaker, designed as a more affordable and portable alternative to the SoundLink Mini.
aux in is broken ,how can it be fixed
aux in is broken ,how can it be fixed ? do i need some Accessories
Это хороший вопрос?
Счет 0
1 Комментарий
@boseman how is it broken? Is the connector physically broken or what is going on with your Bose?
из
Добавить комментарий
1 ответ
Наиболее полезный ответ
@boseman take a look at this guide. Step 6 shows the port soldered onto the board. So it would not be easy. You could try and purchase a broken Bose SoundLink Color and harvest the port from it. Or you could possibly pigtail a separate input port (cable) to it. This will depend on your soldering skills etc. If you can, post some images of the damage (disassembled) with your question. For that use this guide. That would allow us to see what you see and possibly point out where to solder to.
iFixit Изображение
Инструкция
Adding images to an existing question
Сложность:
Очень просто
2 - 5 minutes
Bose SoundLink Color Speaker Изображение
Инструкция
Bose SoundLink Color Speaker Replacement
Сложность:
Сложно
20 - 30 minutes
Был ли этот ответ полезен?
Счет 2
2 Комментариев:
I have uploaded several pictures of it.
Ccould you help me to see whether i can fix it by using the old aux and just fix it (not replace ),
из
@boseman Looks like the walls on the jack have actually cracked. so that would not be something that can be fixed but would require some sort of replacement.
из
Добавьте свой ответ
Kyle буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 2
За последние 30 дней: 11
За всё время: 712
