MBP Display not working, Backlight and computer functions normally
Greetings! I have read through other threads but none of those solutions worked
I replaced the speakers on my MBP and there was no issue, but revently, my display went black and does not work. I tried all the software checks, tried disconnecting and reconnecting the display cable, but nothing. It works fine on an external monitor, and the backlight responds as well.
Additionally, I replaced the LVDS cable, but still the same issue. All of the connectors look okay on the logic board as well, as far as I can see. This is getting super frustrating, since I feel Ive tried everything at this point. Any ideas? Thanks so much!
Edit 1:
Edit 2:
Это хороший вопрос?
9 Комментариев
Using a flashlight shine it through your lids logo to be doubly sure your backlight is not the issue. Do you see the faint image of your desktop and the icons on it?
Sometimes the backlight will fire up doing the boot up process and then go out. We need to know if that is the case here.
из Dan
Hey Dan!
Shining a light doesnt show any faint image.
из Alain Sullivan
@lemellekh2 post some good pictures of your logic board and the connector area. Let's see if you may have popped off a component etc, while replacing the speaker Adding images to an existing question
из oldturkey03
@oldturkey03 Thanks so much for reaching out! I added some pics.
из Alain Sullivan
@lemellekh2 if you can post another one from the other side of the connector. Lets see if you can get close to the solder points.
из oldturkey03
Показать 4 больше комментариев
