Model A1369, 1.6, 1.7, or 1.8 GHz Processor, 64, 128 or 256GB Flash Storage
328вопросов Показать все
Mac turn itself while connected to power, not on battery
Hi!
I have a Mac air a1369. It turns itself the moment I plug it to the wall. Without pressing a power button.
But when its on a battery it doesn’t turn on. Battery is ok.
When its working and I disconnect the power cable it runs off the battery just fine.
Any ideas what can be the problem? SMC chip?
Thanks
Update (09/07/2021)
Это хороший вопрос?
Оценка 0
1 Комментарий:
Let’s get a better view of things, install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see Adding images to an existing question
из
Добавить комментарий
1 ответ
Sadly your battery has hit its limit! Batteries wear-out by both time (years) and number of cycles.
Your battery is 6.5 years old and has 960 cycles. Here’s a bit more on the max lifespan of a battery by cycle Determine battery cycle count for Mac notebooks
Here’s the needed part MacBook Air 13" (Late 2010-2017) Battery and here’s the guide to replace it MacBook Air 13" Mid 2011 Battery Replacement
MacBook Air 13" (Late 2010-2017) Battery Изображение
Продукт
$69.99
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
krupex79 будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 38
