Samsung's tenth flagship Galaxy phone, released in March of 2019. Shipped with Android 9.0 (Pie).
71вопросов Показать все
Touch screen not working
Hi
I have a samsung s10 the touchscreen has stopped working. It started at the top of the screen and it now has spread to the rest of the phone. I don’t want to do a hard reset as I have been unable to send pics etc to the cloud, thanks
Это хороший вопрос?
Оценка 1
1 Комментарий
Samsung s1p plus toch not working
из
Добавить комментарий
3 Ответов
Наиболее полезный ответ
Clare Birtwhistle, the only way to fix this “It started at the top of the screen and it now has spread to the rest of the phone” is by replacing the digitizer. In this phone the display assembly is fused so unless you have the tools to separate it etc. it’s best to replace the display assembly. Samsung Galaxy S10 Screen Replacement
Был ли этот ответ полезен?
Оценка 2
Hi,
Connect a USB mouse to the phone via an OTG cable and use the mouse to navigate through the phone so that you can backup your data to the cloud. Search online for Samsung S10 OTG cable to get results for suppliers that suit you best.
Be aware that the phone’s battery is used to power the mouse so it will discharge more quickly than normal.
After that you can replace the LCD screen + digitizer as described above, to fix the touch problem.
Replacing the screen assembly doesn’t require a hard reset so if you are careful, your data shouldn’t be affected. If you backup your data first nothing untoward will happen to it because of the repair, but odds are if you don’t then it will. Murphy’s Law.
Оценка 1
https://youtu.be/w1m47ALwjGQ
I solved my problem by this video
Оценка 0
Добавьте свой ответ
Clare Birtwhistle будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 35
За последние 30 дней: 146
За всё время: 2,953
