Samsung Galaxy S10 Screen Replacement
Выберете то, что вам нужно
  1. Samsung Galaxy S10 Screen Replacement, Heat the back cover: шаг 1, изображение 1 из 3 Samsung Galaxy S10 Screen Replacement, Heat the back cover: шаг 1, изображение 2 из 3 Samsung Galaxy S10 Screen Replacement, Heat the back cover: шаг 1, изображение 3 из 3
    • Unplug and power off your phone before you begin.
    • Heat an iOpener and apply it to the back cover's right edge for two minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
    • As you wait, take a look at the image of the removed back cover and take note of where the adhesive is located.
    Спросите у FixBot
    Добавить комментарий
  2. Samsung Galaxy S10 Screen Replacement, Create an opening gap: шаг 2, изображение 1 из 3 Samsung Galaxy S10 Screen Replacement, Create an opening gap: шаг 2, изображение 2 из 3 Samsung Galaxy S10 Screen Replacement, Create an opening gap: шаг 2, изображение 3 из 3
    • Rest the heated right edge of the phone on something that is about 0.5 inches (13 mm) thick. This angles the phone for the opening tool.
    • Brace the left edge of the phone with your fingers so that the phone won't slide. Pull on the suction cup with firm pressure.
    • Press the edge of an opening tool into the seam between the back cover and the frame.
    • With the opening tool in place in the seam, slide it back and forth along the seam to loosen the back cover.
    Спросите у FixBot
  3. Samsung Galaxy S10 Screen Replacement, Insert an opening pick: шаг 3, изображение 1 из 3 Samsung Galaxy S10 Screen Replacement, Insert an opening pick: шаг 3, изображение 2 из 3 Samsung Galaxy S10 Screen Replacement, Insert an opening pick: шаг 3, изображение 3 из 3
    • Heat an iOpener and apply it to the same edge of the phone for two minutes.
    • Apply a suction cup to the back of the phone, as close to the center of the right edge as possible (where the adhesive is narrowest).
    • Pull on the suction cup with strong, steady force to create a gap between the back cover and the frame.
    • Insert the point of an opening pick into the gap.
    • Due to tight tolerances and strong adhesive, multiple attempts may be necessary to create a gap for the opening pick.
    • If you are having trouble creating a gap, the adhesive isn't weakened enough. Make sure you have heated the edge until just barely too hot to touch try this step again.
    • You can try applying a few drops of high concentration (over 90%) isopropyl alcohol into the seam to help loosen the adhesive.
    • Do not apply excessive force with the pick, or you will risk cracking the back cover glass.
    Спросите у FixBot
  4. Samsung Galaxy S10 Screen Replacement, Slice through the adhesive: шаг 4, изображение 1 из 3 Samsung Galaxy S10 Screen Replacement, Slice through the adhesive: шаг 4, изображение 2 из 3 Samsung Galaxy S10 Screen Replacement, Slice through the adhesive: шаг 4, изображение 3 из 3
    • Slide the opening pick along the edge of the phone, slicing through the adhesive.
    • Do not attempt to slice the adhesive holding the corners down before applying heat. If you do, you may crack the back cover.
    • Leave a pick in the seam to prevent the adhesive from re-sealing.
    Спросите у FixBot
  5. Samsung Galaxy S10 Screen Replacement: шаг 5, изображение 1 из 2 Samsung Galaxy S10 Screen Replacement: шаг 5, изображение 2 из 2
    • Apply a heated iOpener to the bottom edge of the phone for two minutes.
    • Insert an opening pick into the right edge near the bottom right corner.
    • Carefully slide the pick around the corner. Continue cutting along the bottom edge and around the bottom left corner.
    • If the cutting feels difficult, re-apply heat to the edge before continuing.
    • Leave an opening pick in the seam to prevent the adhesive from re-sealing.
    Спросите у FixBot
  6. Samsung Galaxy S10 Screen Replacement: шаг 6, изображение 1 из 3 Samsung Galaxy S10 Screen Replacement: шаг 6, изображение 2 из 3 Samsung Galaxy S10 Screen Replacement: шаг 6, изображение 3 из 3
    • Continue heating and slicing around the remaining edges of the phone.
    • When cutting around corners, be sure that the corner is thoroughly heated.
    Спросите у FixBot
  7. Samsung Galaxy S10 Screen Replacement: шаг 7, изображение 1 из 3 Samsung Galaxy S10 Screen Replacement: шаг 7, изображение 2 из 3 Samsung Galaxy S10 Screen Replacement: шаг 7, изображение 3 из 3
    • Once you have sliced around the phone, twist an opening pick in one of the edges to help separate the back cover from the frame.
    • Lift the back cover slowly. Use opening picks to slice any remaining adhesive.
    • Remove the back cover.
    • During reassembly, this is a good point to power on your phone and test all functions before you seal the back cover in place. Be sure to power your phone back down completely before you continue working.
    • Follow this guide to reinstall the back cover, transfer and install the camera bezel, and replace the adhesive.
    • If desired, you may reinstall the back cover without replacing the adhesive. Remove any large chunks of adhesive that might prevent the back cover from sitting down flush. After installation, heat the back cover and apply pressure to secure it.
    Спросите у FixBot
  8. Samsung Galaxy S10 Screen Replacement, Remove the midframe: шаг 8, изображение 1 из 1
    • Remove the eight 4 mm Phillips screws securing the top midframe to the phone.
    Спросите у FixBot
  9. Samsung Galaxy S10 Screen Replacement: шаг 9, изображение 1 из 2 Samsung Galaxy S10 Screen Replacement: шаг 9, изображение 2 из 2
    • The midframe is still held in place by a few plastic clips around the edge.
    • Insert the point of a spudger into the notch on the right edge of the midframe, near the volume up button.
    • Pry up to loosen the midframe from the phone.
    Спросите у FixBot
  10. Samsung Galaxy S10 Screen Replacement: шаг 10, изображение 1 из 3 Samsung Galaxy S10 Screen Replacement: шаг 10, изображение 2 из 3 Samsung Galaxy S10 Screen Replacement: шаг 10, изображение 3 из 3
    Спросите у FixBot
  11. Samsung Galaxy S10 Screen Replacement, Disconnect the battery: шаг 11, изображение 1 из 3 Samsung Galaxy S10 Screen Replacement, Disconnect the battery: шаг 11, изображение 2 из 3 Samsung Galaxy S10 Screen Replacement, Disconnect the battery: шаг 11, изображение 3 из 3
    • Insert the flat end of a spudger underneath the battery connector, which is attached to the motherboard below the rear-facing camera.
    • Pry upwards to disconnect the connector from its socket.
    • When you disconnect connectors like these, be careful not to dislodge the small surface-mounted components surrounding the socket.
    • Gently push the battery's flex cable away from the motherboard socket to prevent accidental contact.
    Спросите у FixBot
  12. Samsung Galaxy S10 Screen Replacement, Remove the loudspeaker: шаг 12, изображение 1 из 1
    • Remove the seven 4 mm Phillips screws securing the lower midframe.
    Спросите у FixBot
  13. Samsung Galaxy S10 Screen Replacement: шаг 13, изображение 1 из 2 Samsung Galaxy S10 Screen Replacement: шаг 13, изображение 2 из 2
    • Insert the point of a spudger underneath the top right corner of the lower midframe.
    • Pry up to release the midframe from the phone.
    Спросите у FixBot
  14. Samsung Galaxy S10 Screen Replacement: шаг 14, изображение 1 из 3 Samsung Galaxy S10 Screen Replacement: шаг 14, изображение 2 из 3 Samsung Galaxy S10 Screen Replacement: шаг 14, изображение 3 из 3
    • Grasp the loosened end of the midframe with your fingers and lift upwards slowly.
    • Wiggle the midframe slightly to help release the remaining edge clips.
    • Remove the lower midframe. The loudspeaker is built into the lower midframe.
    Спросите у FixBot
  15. Samsung Galaxy S10 Screen Replacement, Disconnect the screen: шаг 15, изображение 1 из 2 Samsung Galaxy S10 Screen Replacement, Disconnect the screen: шаг 15, изображение 2 из 2
    • Use the flat edge of a spudger to pry up and disconnect the display connector from its motherboard socket.
    Спросите у FixBot
  16. Samsung Galaxy S10 Screen Replacement, Slice through the screen adhesive: шаг 16, изображение 1 из 1
    • Flip the phone over so that the display is facing up.
    • Apply a heated iOpener to the right edge of the screen for two minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the internal battery is susceptible to heat damage.
    Спросите у FixBot
  17. Samsung Galaxy S10 Screen Replacement: шаг 17, изображение 1 из 3 Samsung Galaxy S10 Screen Replacement: шаг 17, изображение 2 из 3 Samsung Galaxy S10 Screen Replacement: шаг 17, изображение 3 из 3
    • Apply a suction cup to the heated edge of the display.
    • Pull up on the suction up with strong, steady force to create a gap.
    • Depending on the age of your device, this may be difficult. If you have trouble, apply more heat and try again.
    Спросите у FixBot
  18. Samsung Galaxy S10 Screen Replacement: шаг 18, изображение 1 из 3 Samsung Galaxy S10 Screen Replacement: шаг 18, изображение 2 из 3 Samsung Galaxy S10 Screen Replacement: шаг 18, изображение 3 из 3
    • Slide the opening pick along the right edge to slice through the adhesive.
    • Leave the opening pick in the corner to prevent the adhesive from resealing.
    Спросите у FixBot
  19. Samsung Galaxy S10 Screen Replacement: шаг 19, изображение 1 из 1
    • Apply a heated iOpener to the bottom edge of the display for one minute.
    Спросите у FixBot
  20. Samsung Galaxy S10 Screen Replacement: шаг 20, изображение 1 из 2 Samsung Galaxy S10 Screen Replacement: шаг 20, изображение 2 из 2
    • Slide an opening pick along the bottom edge to slice through the adhesive.
    Спросите у FixBot
  21. Samsung Galaxy S10 Screen Replacement: шаг 21, изображение 1 из 3 Samsung Galaxy S10 Screen Replacement: шаг 21, изображение 2 из 3 Samsung Galaxy S10 Screen Replacement: шаг 21, изображение 3 из 3
    • Repeat the heating and slicing procedure for the remaining display sides.
    Спросите у FixBot
  22. Samsung Galaxy S10 Screen Replacement: шаг 22, изображение 1 из 3 Samsung Galaxy S10 Screen Replacement: шаг 22, изображение 2 из 3 Samsung Galaxy S10 Screen Replacement: шаг 22, изображение 3 из 3
    • Use an opening pick to pry open and slice through any remaining adhesive.
    Спросите у FixBot
  23. Samsung Galaxy S10 Screen Replacement, Remove the screen: шаг 23, изображение 1 из 2 Samsung Galaxy S10 Screen Replacement, Remove the screen: шаг 23, изображение 2 из 2
    • Thread the display panel connector through the frame.
    • If you're having trouble, you can choose to cut the display panel cable in order to remove the display.
    Спросите у FixBot
  24. Samsung Galaxy S10 Screen Replacement: шаг 24, изображение 1 из 2 Samsung Galaxy S10 Screen Replacement: шаг 24, изображение 2 из 2
    • Remove the screen.
    • If you are using a custom-cut adhesive, follow this guide for instructions on how to remove the old adhesive and attach the replacement screen.
    • If you're using Tesa tape to reattach the screen, follow this guide.
    Спросите у FixBot
Заключение
After you've completed the repair, follow this guide to test your repair.
47 человек успешно провели ремонт по этому руководству.
Arthur Shi
Участник с: 01/03/18
343 723 Репутация
Автор 915 руководств
Команда
iFixit Участник iFixit
Staff
123 членов
Автор 28 236 руководств
6 Комментарии к руководству
Bonjour, est ce que le téléphone retrouve sa norme ip68 après le changement de l’écran ? merci d’avance
Bastian - Ответить Поделиться
Hello! The repair will not restore IP68 resistance. You normally need specialty presses in order to seal a phone to IP ratings.
Bonjour! Ça ne sera pas. Vous avez besoin de machines spéciales pour restaurer le téléphone sur IP68.
Arthur Shi - Ответить Поделиться
Can the rear lens cover be removed without having to remove the entire back? I have a foggy lens that needs cleaning.
Pasith Phommarath - Ответить Поделиться
Oui je veux un autre ecran
Bétina François - Ответить Поделиться
Je veux un autre ecran Samsung galaxy S10
Статистика просмотров:
За последние 24 часов: 22
За последние 7 дней: 151
За последние 30 дней: 827
За всё время: 166,362
