Model Number A1707. Released June 2017, this MacBook Pro features Kaby Lake processors up to the 2.8 GHz quad-core Intel Core i7 processor with Turbo Boost up to 3.8 GHz.
327вопросов Показать все
Fan runs over full speed after battery replacement
I have the same issue after replacing the batteries. Only the right side fan runs at full rpms. I replaced both fans and still the same issue. I wonder if I damaged something on the board related to the right fan. Anyone have any ideas besides buying a new logic board?
Update (12/16/2021)
. Here is the screen shot from the App.
Это хороший вопрос?
Оценка 0
Добавить комментарий
2 Ответов
@kirbybj - Review steps 41 ~ 43 for each fan unit in this guide MacBook Pro 15" Touch Bar 2017 Battery Replacement Did you nick the ribbon cable?
See what the onboard diagnostics tells you. Restart your system and press the D key. Let us know if you get any errors.
Reference: Mac startup key combinations
Был ли этот ответ полезен?
Оценка 0
4 Комментариев:
After running diagnostics the message is this. There may be an issue with the fan reference code PPS004. Additional reference code PPS003.
из
I have also tried to reset the SMC but it didn’t help.
из
@kirbybj - Are you sure you wrote the error message correctly? PPS003 & PPS004 are not listed maybe PPT003 PPT004 which are battery errors.
Let’s get a better view of things, install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see Adding images to an existing question
из
OMG I am so sorry, it is There may be an issue with the fan reference code PPF004. Additional reference code PPF003. I was voice texting and didn't realize. I will install that App CoconutBattery. I need to restore my Mac. I Reset it after having this issue. I was desperate. Give me about an hour to do so. Thank you Dan.
из
I also saw a Youtube video that showed a component that gets knock off near the edge of the board when changing batteries, Not sure If I did that.
Оценка 0
Добавьте свой ответ
Betty Kirby будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 7
За всё время: 239
