Monitor has no sound
Where can I order the speaker for the monitor?
Thank you
Это хороший вопрос?
Thank you
Это хороший вопрос?
Hi,
Have you actually proved that the speaker is the problem, i.e. does it test OL (open circuit) when tested with an Ohmmeter?
If the speaker is faulty, looking at images in the ifixit Замена динамика Infant Optics DXR-8 guide, the monitor speaker is an 8Ω 0.5W mini speaker.
I don’t know the actual dimensions so to get a suitable replacement, search online for (insert diameter of speaker) 8Ω 0.5W mini speaker. For example, here is a 1” model that should work.
If the speaker tests OK there may be a problem with the camera’s microphone or in the monitor motherboard.
Был ли этот ответ полезен?
За последние 24 часов: 1
За последние 7 дней: 5
За последние 30 дней: 38
За все время: 2,110
