Repair guides for the Samsung Galaxy J5 (2015), released June 2015.
45вопросов Показать все
Why is my screen glitching during gaming
When i am gaming on this phone (Samsung Galaxy J5) even on 60 fps the screen will either freeze or if i was moving my finger on the screen the display will recgonize that my touch is still there even tho i put my hands of the phone
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
Hi @rugdug,
Try using the phone in safe mode and check if it works better.
If it does a downloaded app is the cause of the problem. You will need to uninstall each downloaded app, one by one and test the phone in normal mode between each uninstall to see if it works OK. When it does the last downloaded app that was uninstalled was the culprit. A downloaded app is one that you downloaded and installed onthe phone and wasn’t pre-installed on the phone when you first got it.
Also if it only happens on one game it may be that the phone doesn’t have the system resources to play it properly so it glitches or freezes because it can’t cope.
Был ли этот ответ полезен?
Оценка 1
1 Комментарий:
Yes, that is a good solution. It's actually what I was going to say.
из
Добавьте свой ответ
RugDug будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 4
За последние 30 дней: 7
За всё время: 35
