Hello,i have samsung smart tv 50cm and the screen is cracked is it pos
Hello,i have samsung smart tv 50cm and the screen is cracked is it possible to repair.I live in alsdorf.Thank you.
Это хороший вопрос?
Это хороший вопрос?
Usually a new TV panel costs more than a new TV. What's your TV's model number, so I can check the price of a panel?
Был ли этот ответ полезен?
Hi,
Cracked TV screens cannot be repaired, they have to be replaced.
Disconnect the power from the TV and then remove the back cover from the TV.
Check if you can find the make and model number of the LCD panel which should be printed somewhere on the back of the panel itself.
Once you have found it, search online using that information to hopefully find a replacement.
Replacement panels can cost nearly half as much as a new TV.
An option to consider if you can’t find one, is to advertise your TV as faulty screen-cracked, good for parts to try and recoup some of the cost towards a new TV. Working TV boards are always in demand.
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 6
За всё время: 112
