CD opening isn't opening
- CD opening isn't opening
Это хороший вопрос?
Ali HD1 you really did not give us a lot of information. It sounds like you are saying that your tray is not opening. You should also tell us more about the history of this and what you have tried thus far to fix this. I suggest that you run the Test mode to see if you can make a better diagnosis on what has failed. Sony DVP NS715 Test Mode
Был ли этот ответ полезен?
За последние 24 часов: 0
За последние 7 дней: 6
За последние 30 дней: 22
За все время: 379
Need a bit more here!
∙ Do you hear any sounds?
∙ Is the player powering up?
∙ Do you get an error code on the display?
из DanJ
Do you have a multimeter?
из Andrew S
