iPhone 3GS Antenna Cable
does the antenna connector have the number 7 on it, lower right hand side?
Это хороший вопрос?
Это хороший вопрос?
Yes, I believe that is one of the antenna connectors. You can see it in step 10 of this guide.
Был ли этот ответ полезен?
Just wanted to provide some more details because I had to deal with this myself just this past week:
In the 3GS, the #7 connector is for the Cellular/WWAN antenna sticker which is on the back of the lower dock assembly (the rest of that assembly is for the mic, speaker, and charge port through connector #4). Please note that the WiFi and Bluetooth antenna sticker is separated and part of the top assembly and connected to the logic board through #6.
This contrasts to the behavior of the earlier 3G model, which had a single antenna sticker on the lower dock assembly for Cellular/WWAN, WiFi, and Bluetooth (WiFi & Bluetooth was in the top left, Cellular/WWAN was in the bottom right of the sticker - you can clearly see the separation). Additionally, there was no #7 connector, so my "assumption" is that the #4 connector handled all of that in the earlier model.
Hope that helps! In my case, I pulled off what appears to be a resistor (not sure, too small) near the #7 connector while pulling up the warranty sticker. Thankfully, I'm using this older phone as an iPod Touch, so everything works great for me even though I did that.
За последние 24 часов: 0
За последние 7 дней: 1
За последние 30 дней: 5
За всё время: 3,161
