Why is my laptop having power on issues after battery replacement?
I replaced the battery in my laptop by following a YouTube tutorial and everything was fine for 24 hours. I could see the cycle count reset to 1 after a full charge, but now the battery isn’t even recognized in system information and the laptop will not work without being connected to the power adapter. I found this out by opening the laptop expecting the screen to immediately light up and after pressing the power button a few times and hearing the chimes for only the first few presses, I plugged it in. So basically, what did I mess up? Considering it worked for 24 hours I’m at a loss. I was trying to not have to dish out $1500 and rather just the $120 for the battery but will I now be out the sum of both?
Update (05/10/2022)
Also, in doing this, I realized how laggy and slow my laptop now is, if that helps!
Это хороший вопрос?
3 Комментариев
Let’s get a better view of things, install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see Adding images to an existing question
из Dan
@danj I received the replacement battery today, but now the old one is starting to charge again! Should I continue with the replacement?
из Jen Lindsey
@jennygee17 - Post a new snapshot of CoconutBattery so we can see what it looks like
из Dan
