Ryobi P214 — это аккумуляторная ударная дрель, работающая от литий-ионного аккумулятора 18 В, оснащенная патроном 1/2 дюйма, крутящим моментом до 68 Н·м и скоростью вращения 0–400 / 0–1600 об/мин. На этой странице представлена подробная информация и руководства по ремонту модели P214, которая включает функцию удара для сверления каменной кладки, 24 настройки муфты и совместимость с системой One+ для взаимозаменяемости аккумуляторов.
Can't remove chuck from drill
I have the ryobi p214 cordless drill and no matter what I cant remove the chuck. I took the screw out from inside the jaws and I put an allen wrench in and held it with the jaws. I managed to turn the chuck counter clockwise but it just barely spins without loosening at all. How can I get the chuck off?
Это хороший вопрос?
Счет 1
5 Комментариев
@archiep once you got the allen wrench locked, you placed your drill in REVERSE (lowest torques setting)and you do have a full battery? Now pull the trigger. Careful, It'll kick a bit and you got to hang on to it and watch your wrist.
из
I did this, but the drill started smoking and it also kept auto braking unfortunately.
из
I have the same problem? I cant tighten the chuck enough to stop the drill bit just spinning in the chuck , so , I want to fit a new one but cant remove the old one? Cant see any screw / bolt up inside the chuck at all? Hopeless system?
из
Had the same problem so dismantled the drill down to the point where I had just the shaft with 2 flats on the end, clamped it in the vice , 10mm hex key in the chuck and heated the hell out of the old chuck, it let go with a bang and the thread is not a 1/2" 20 thread as mentioned, still to indentify, be careful during disassembly as a lot of small gears and parts, photograph each stage.
из
Also good to note that the screw is a reverse thread
из
Добавить комментарий
1 ответ
Наиболее полезный ответ
A few things that may help; first instructions on how to deal with the situation. here next a reminder that this has a 3 year warranty in case that still applies and your owner's manual here in case you need it, which gives instructions on pursuing your warranty or service. Last; schematics and parts are available here
Был ли этот ответ полезен?
Счет 1
2 Комментариев:
Thank you for the useful content, however, the article link is doing something different than what I'm trying to do. I don't have a bit stuck in the chuck, I'm trying to remove the chuck from the body of the drill. I used the schematic you shared to illustrate my situation.
из
OK, well, in the very unlikely event that @oldturkey03 's advice didn't do it for you, (he's a pretty darn sharp tack) I did find an answer to that too...somewhere but should have read your question more carefully.
из
Добавьте свой ответ
Archiep буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 6
За последние 30 дней: 41
За всё время: 2,714
