M3D Micro — это доступный 3D-принтер небольшого компактного размера.
Help recognizing burned component
Hi M3D Micro owners!
I have recently noticed one component (I think is a transistor) is burned, and I need help knowing which one it is.
I didn't find any schematics for the board, so I have no clue.
I would really appreciate any help here. I want to replace the component and fix the printer.
Thanks!
Это хороший вопрос?
Счет 1
4 Комментариев
Which board is this? Is this the logic board or the Power and Data board?
из Поделиться
I think my Micro is the first one they released, since I bought it from Kickstarter. Therefore it only has one logic board.
I have edited my comment, adding the full board image.
Thanks Jacob!
из Поделиться
Это стабилизатор питания на 3,3V для микроконтроллера. Если его пробило, через него мог сгореть и контроллер.
This is a 3.3 V power stabilizer for the microcontroller. If it broke through, the controller could also burn through it.
из Поделиться
SOT-23 XC6206P332 or XC6206 or SMD(662K) 3,3 В/0.5A
из Поделиться
Добавить комментарий
2 Ответов
Выбранное решение
check out this datasheet
https://www.diodes.com/assets/Datasheets...
GW9 = AP2127N-3.3TRG1 = 3.3V regulator
Был ли этот ответ полезен?
Счет 4
3 Комментариев:
@ruggb same result for me. Got the right symbol and right marking.
из Поделиться
Thank you! I think you have found it! I will order the component, replace it and let you know.
из Поделиться
I found a cheap option to order it from Europe, if someone else is interested:
https://a.aliexpress.com/_uv6bsR
из Поделиться
Hi @kuruchy
For what it is worth here's a zoomed in image from Step.7 of the ifixit Замена портов питания и передачи данных M3D Micro which shows the component.
Although what GW9 (I think) means I don't know. Looking at this link it may be some sort of voltage regulator?, but as to its value that is also something else, I don't know.
Then again it may just be the component manufacturer's marking and not a value marking
(click on image to enlarge)
Hopefully a start
Счет 3
4 Комментариев:
hi @jayeff, thanks 👍.
Taking a look at the circuit itself, and how it got burned, it makes total sense that it is a voltage regulator.
With GW9 at least I have a hint on how and what to test.
из Поделиться
If anyone has more info to which component exactly is, would be great.
из Поделиться
Taking a look at all the manuals you added, it could also be a voltage detector.
из Поделиться
@kuruchy
True.
Long shot perhaps but looking at the image you provided are there any other similar sized ICs on the board having the same marking as the faulty one?
Sometimes more than one may be used in a circuit.
If there is it may give some idea as to what it might do, depending on where it is situated.
Very hard to know without a schematic. ;-(
из Поделиться
Добавьте свой ответ
Bruno Retolaza буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 3
За последние 30 дней: 39
За все время: 800
