Sanyo DP50747 tv power issue
t
Tv started turning its self off . let it sit and could restart with remote did this three times . stopped using it and now no power to screen . Could this be that ft8ah250vp fuse as well ?
Это хороший вопрос?
t
Это хороший вопрос?
Hi @kjc11
Start by going through the no power troubleshooting flowchart and check what it shows.
Был ли этот ответ полезен?
ill try the fuse first as it sounds like other persons issue was resolved with it
If it was the fuse you quoted in your question, once it blows it is blown and it doesn't reset again and this doesn't correspond with what you said about it being able to restart again albeit without a screen
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 2
За всё время: 29
1 Комментарий
Can you take the back off the TV and upload pictures of the circuit boards inside? Adding images to an existing question
из Andrew S
