After about a 18 months of use, my Mug 2 stopped holding a charge at all, dying as soon as it was lifted off the base. After contacting support, the best Ember could do was offer to sell me a replacement mug for $99 dollars.
Not wanting to just buy a new mug which would likely face the same fate eventually, I figured I would at least try to repair my mug myself.
Thanks to the tips in this thread, I was able to get my Mug 2 apart using a couple of strap wrenches: one wrench wrapped around the main body of the mug and the other wrapped as best I could around the base. This allowed me to get enough friction and torque to turn the base the 15 degrees that Propeller Head mentioned. I was then able to carefully pry apart the base from the mug without damaging the ribon cable connecting the two pieces.
As others have mentioned, the 18650 batteries in the battery pack can be replaced if you have the tools and expertise/confidence to weld new batteries to the existing, proprietary BMS board.
I don't have a spot welder so what I ended up doing instead was using 2 high capacity/high discharge 14500 batteries ($9) in a AA battery holder ($5) soldered to the old BMS like so:
The BMS seems to handle the 14500 batteries just fine as long as everything is connected correctly.
With the BMS tucked between the bottom board and the battery holder (with some electrical/conformal tape to prevent any shorts), everything fits snugly underneath the shield and the mug can be reassembled using the strap wrenches.
Even with the highest capacity 14500 batteries, this mod does reduce the battery life of the mug by about 20-30% (compared to new 18650 batteries) but does allow you to (somewhat) easily replace the batteries if they ever start to degrade.
Был ли этот ответ полезен?
Проголосовали
Отменить
Оценка
2
Отмена
Scroll through this thread to find the appropriate place for this comment. Then, click "Attach comment to this post" to move it.
5 Комментариев
I am unable to find a B0664-LF replacement battery
из Splint
The Ember mug cannot be serviced as there is an anti-tamper locking pin on the metal base lip. The pin could be released by drilling a 2 mm hole at a very acute angle that intercepts the pin. Then pushing the pin out of the way and rotating the bottom section 10 degrees. I have photos 1agkirk2@gmail.com
из Alan Kirk
@alankirk50251 That is something that I was concerned about when doing my teardown; I noted that pin but couldn't be sure of its function due to the head damage to the plastic. If that's the case, they deserve some major negative points for deliberately booby trapping the base so the battery can't be replaced.
из Jerry Wheeler
@alankirk50251 Can you create an answer to this question and post your pictures? I'm sure we'd all love to see what you found.
Adding images to an existing question
из Jerry Wheeler
This worked great to get to the battery on the Ember Mug 2 (not the travel mug). Here are more details. I used a strip of neoprene rubber to grip the base as I twisted it clockwise (about 15 degrees - it will stop when it hits the right spot). I also used the neoprene rubber to help pull the base off the mug. The ribbon cable is attached to a connector, but I had to remove 4 Torx screws (T6) to remove the battery shield to allow the ribbon cable connector to be pulled straight up from the board. The board can be pulled straight out (you will probably need to pop off the black light-pipe cover that seems to be snapped in before you can pull the board out). The battery pack seems to be glued to the board. I haven't tried to separate it yet. The battery part number on my mug is INR18650 MH1-2S1P made by BYD. I can't find that part number online but I may be able to replace the individual cells. If I can figure out how to add pictures here , I will.
из JKBrick
