Выпущен: Dell G5 15 5500, май 2020 г., идентифицируется по номеру модели 5500. Игровой и профессиональный ноутбук Dell с дискретной видеокартой. Нормативный номер: P89F, нормативный тип: P89F003. Предшественником является Dell G5 5590.
Stopped dead while using; Power cord light goes out when connected
I used my Dell G5 15 5500 (purchased in November 2020) mostly for Minecraft and email... a little bit of surfing. It was pretty much plugged in all the time. I was surfing and it stopped working without warning. Tried turning on again but no signs of life... no screen, no keyboard lights, nothing, not even life enough to try POST. I tried unplugging power cord, waited, plugged it in and it looked like there was a spark when the cord was plugged in - also the blue light on the power cord goes out as soon as it is plugged into laptop. I thought it was a bad power cord/brick so ordered a new one. New cord had same result except no spark.... and new power cord blue light also goes out when connected to laptop. Laptop still dead. Holding power button down for at least 15 seconds shows no signs of life. I think this happened within a day of some sort of update, maybe windows update but not sure what type. Does this make any sense?! This has been a great computer for me and still had lots of useful life left, heh, until there wasn't any life at all! Has this happened to anyone else? Thanks
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Выбранное решение
Power mosfet has gone bad or a cap has blown on the board. The chargers have a fail safe built in. If you plug a charger into a laptop with a board issue the charger will go into safe mode which means it turns itself off. To reset it you need to unplug it and plug it back in. I’d find a local computer shop to take a look unless your confident in testing electronics.
Был ли этот ответ полезен?
Счет 2
1 Комментарий:
Thank you @strongbow
из Поделиться
Добавьте свой ответ
Pat (he/him) Harmon буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 3
За последние 30 дней: 25
За все время: 777
