HP Pavilion 15-cc561st is a laptop from the HP Pavilion 15-cc500 Laptop PC series. Released in 2017 July with product number 1KU29UA.
Вопросов 2 Показать все
Why is my disk making noices?
My disk makes a noise every 5-8 seconds, additionally the computer has become slower. I have tried cleaning the disk and nothing has changed. Do I need a new disk?
Это хороший вопрос?
Оценка 0
Добавить комментарий
Ответов (2)
Наиболее полезный ответ
Are you sure it is not the cooling fan? Otherwise your drive is likely dying. Immediately back up any important data.
Oh and upgrade to an SSD drive for a faster computer.
Был ли этот ответ полезен?
Оценка 1
1 Комментарий:
I have switched to a sdd and the noice kept going. Any alternatives you would recommend checking out
из
If your HDD is making noise, it is most likely damaged in some way and needs to be swapped out immediately. You most likely cannot backup any files from a corrupt HDD, but if you manage to, that's nice. However, if it's too damaged you can't simply replace or fix any parts of the HDD. You will have to buy a new one.
Оценка 0
4 Комментариев:
I have switched to a sdd and the noice kept going. Any alternatives you would recommend checking out.
из
@Isaias Savoca
What is the make and model number of the laptop?
If the HDD was replaced with an SSD the only things left that can make a sound is the fan, the CD drive (if CD inserted or maybe even if not) or if you have audio playing through the speakers, unless your model laptop has two storage drives i.e. SSD and HDD of course
из
The model is a Hp Pavilion 15-cc6xx. It doesn't have a cd drive. the noice comes in two types it either comes and goes every 5-7 seconds or at times the noice is consistent for a entire minute and then stops for another. Checked the fan and it looked fine to my opinion(noob)
из
@Isaias Savoca
Can you isolate where the noise is coming from?
Have you tried muting the speakers to see if the noise emanates from them?
Since you have replaced the HDD with an SSD, the only moving part is the fan so unless it is a "ticking" type noise as sometimes happens with hot components or a whining noise which could be from a coil in the power circuit there's nothing else.
Post a video which has audio so it can be heard on ifixit
Here's how Adding images to an existing question.
Adding video is the same as images as you are just uploading the video file.
из
Добавьте свой ответ
Isaias Savoca будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 106
