water got in and I took it apart but something went bad and it quit wr
where can i send this and my forerunner 235 to get fixed...water got in it.
Это хороший вопрос?
Это хороший вопрос?
The impurities in the water causes corrosion and provides circuit paths for the electricity which were not in the watch's operating design and could damage the components. The corrosion starts immediately and is ongoing until it is completely cleaned away
First do not try to charge or to turn on your watch and then remove the battery as soon as possible from the watch to minimize any further damage.
Then you need to dis-assemble the rest of the watch and clean all the affected parts using Isopropyl Alcohol 99%+ (available at electronics parts stores) to remove all traces of corrosion and water. If possible do not use "rubbing alcohol" as in some cases this is only 70% IPA or less, can contain additives and is not as effective. If you do have to use it check the label to verify the amount of IPA. The higher the percentage of IPA the better
Here is a link that describes the process. Electronics Water Damage
As always with electronics, especially surface mounted pcb be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board. The ends of any flex cables and their connectors need to be cleaned as well
Hopefully after you have done all this the watch might possibly work correctly again.
Here is a video that may help. At least to initially gain access to the battery
If this process seems too daunting, take your watch to a reputable, professional electronics repair service, experienced in liquid damage repair and ask for a quote for a repair. If you decide to do this, do it sooner than later.
Был ли этот ответ полезен?
За последние 24часов: 0
За последние 7 дней: 7
За последние 30 дней: 15
За всё время: 153
water must have gotten in the 235 and it started vibrating and wouldn't stop...so i held the button down (upper left) and it stopped but it won't turn on now. if i connect charger it starts nonstop vibration with dead screen.
из Aric W Street
