It can't start
My motor bike is not starting
Это хороший вопрос?
If your Bajaj Discover motorcycle is not starting, here are a few things you can check:
If you are not comfortable performing these checks yourself, it may be best to take your motorcycle to a professional mechanic for diagnosis and repair.
Был ли этот ответ полезен?
Try kick start maybe your battery is worn out
Find your spark plug location. It's may be right and left side of the engine's nearby top side. Their have an adaptor to connect spark plug and that wire. Remove adaptor and directly keep the wire near by engine and kick the vehicle to start. It may cause to electrical shock. So do it carefully. And check any spark is present or not....
Start with the basics 👍
If it’s been sitting, fuel or plugs are usually the culprit.
За последние 24 часов: 7
За последние 7 дней: 39
За последние 30 дней: 166
За всё время: 8,282
13 Комментариев
Geoffrey Ouko what exact model is your motor bike? What have you checked? Do you have fuel? Do you have spark? Did anything happen to it or did this just start all of a sudden?
из oldturkey03
My motor cycle not start
из DHANANJOY MAHATO
Bettry charging
Palag problem
Indicetar chlu
из Jayram Divkar
البوجية لا تعطي كهرباء قوي
Translation Arabic - English
The spark plug does not give off strong electricity
из فجر
@fgr31679 What make and model bike? What engine size? What year? What have you checked?
Translation
@fgr31679 ما نوع الدراجة وموديلها؟ ما حجم المحرك؟ ما العام؟ ماذا فحصت؟
из oldturkey03
Показать ещё 8 комментариев
