iPod Classic 6th Generation. Model A1238 / 80, 120, or 160 GB hard drive / black or silver metal front
iPod Classic no response
My friend gave me an iPod classic he didn't use anymore. when I plugged it in, It started to bootloop like crazy. I left it plugged in for a while and let it do its thing, hoping it would turn on. I unplugged it and plugged it back in and suddenly I'm getting absolutely no response from the iPod. No charging screen, no bootlooping, I can't even hear the hard drive spinning (which I could before and it sounded like any old hard drive should). I've been wanting a classic for years and now that I have one I'm really hoping I can fix it without opening it up. Has this happened to anyone else?
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
Hi
Chances are you battery has failed
Heres a replacement guide
iPod Classic Battery Replacement
Heres a replacement part
Thick battery
iPod Classic (Thick) Battery
Thin battery
iPod Classic (Thin) Battery
depending on the iPod storage and thickness you might need to get ether if these batterys
Hopefully this helps
Any questions please ask
Replace a battery compatible with 80, 120, and 160 GB thin iPod Classics. Part #616-0229. 650 mAh. Изображение
Товар
$13.99
Replace a battery compatible with a 160 GB Thick iPod Classic. Part #616-0232. 850 mAh. Изображение
Товар
$14.99
Был ли этот ответ полезен?
Счет 1
2 Комментариев:
But if the battery was bad would it even try to turn on and bootloop? It was doing that for probably a good 15 minutes until I unplugged it. I did notice that it died immediately when it was unplugged.
из
@lemaxstudios
Yes it will even do that if it has a bad battery:-)
Iv seen this a couples times across various devices and 9/10 this fixed it:-)
из
Добавьте свой ответ
Lemax Studios буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 0
За последние 30 дней: 3
За всё время: 99
