Mid 2006 / Model Number: A1181 / black or white case / 1.83 or 2.0 GHz Intel Core Duo processor
MacBook backlight flickering screen
Hello guys
i have a macbook 13" with a backlight problem. The backlight flickers and sometimes the backlight goes away.
How can i fix this?
Это хороший вопрос?
Счет 1
8 Комментариев
Please give us the last three figures of your serial number so we know your exact machine. When the backlight goes away can you still see the desktop? Does anything change when you move the screen up and down?
из
I can give you a better answer if you answer.
из
The flickering screen returned and it is really annoying.
Is it the LCD inverter or can it be the LCD panel, which causes the backlight flickering?
Please help me.
из
Replace the CCFL bulb in your LCD or buy a new LCD panel.
из
So here are the last three Figures: U9B
when the backlight goes away I can still see my desktop. Sometimes when I just close the macbook and open it again the backlight works.
из
Показать ещё 3 комментариев
Добавить комментарий
2 Ответов
Выбранное решение
Well, if that returned after the SMC issue, in order of cost and probability the culprits may be:
1. A Pinched Inverter Cable
2. An aging/Failing Inverter
3. An aging/failing backlight lamp
4. (Really, really rare, so rare that I wouldn't take in account): Aging capacitors on the Logic Board
Usually, in a pinch, changing 1-2 fixes the whole mess.
Был ли этот ответ полезен?
Счет 2
1 Комментарий:
I replaced the inverter and it works great now :)
Thank you for your help
из
First make sure you don't have any settings to dim the display. Check your system preferences and power settings.
Is the brightness at the highest setting now? Does it still not appear to be that bright as if it were new? If so your display lamps are near the end of their life. You'll need to get a new display unit. The florescent lamps used in the older macs wear out.
The other possibility is the LCD lamp power system on the main logic board (inverter) cable is loose or the inverter circuit has a bad solder joint or one of its components going south.
MacBook Core Duo LCD Panel Replacement
Try resetting the cable and see if any corrosion on the solder joints. Cleaning might help. Did you get your system wet at some point?
Unless you are a very good micro-electonics solder thats as far as you should go. Over heating the components can kill them and the joints are very delicate.
It maybe time for a new laptop unless you can fine some used parts. Sorry ;-{
Счет 1
1 Комментарий:
Thanks for your reply.
Sometimes if i move the screen the backlight doesnt flicker.
Maybe it is only the inverter cable.
из
Добавьте свой ответ
Fuad буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 3
За последние 7 дней: 16
За последние 30 дней: 33
За всё время: 18,943
