Repair guides for the Huawei Mate 20 Lite Android smartphone, released in September 2018. Model numbers SNE-AL00, SNE-LX1, SNE-LX2, SNE-LX3, INE-LX2.
Вопросов 20 Показать все
The screen is cracked but the phone still works?
I turned the phone on but the screen doesn't work where its cracked and it has water inside of it but it still makes noises
Это хороший вопрос?
Оценка 1
Добавить комментарий
Ответов (2)
Наиболее полезный ответ
Probably only the display is broken. Máte 20 lite can starting also without display, like many phones. Replace the display should solve the problem.
Был ли этот ответ полезен?
Оценка 1
Hi @daisyhiggins
The screen will have to be replaced and also the rest of the phone needs to be checked and cleaned in case any water has penetrated through to it as well
The impurities in the water causes corrosion and provides circuit paths for the electricity which were not in the phone's operating design and could damage the components. The corrosion starts immediately and is ongoing until it is completely cleaned away
First do not try to charge or to turn on your phone and then remove the battery as soon as possible from the phone to minimize any further damage.
Then you need to dis-assemble the rest of the phone and clean all the affected parts using Isopropyl Alcohol 99%+ (available at electronics parts stores) to remove all traces of corrosion and water. If possible do not use "rubbing alcohol" as in some cases this is only 70% IPA or less, can contain additives and is not as effective. If you do have to use it check the label to verify the amount of IPA. The higher the percentage of IPA the better
Here is a link that describes the process. Electronics Water Damage
As always with electronics, especially surface mounted pcb be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board. Remove the shields that may be covering some components as the water may have got in under there. The ends of any flex cables and their connectors need to be cleaned as well
Hopefully after you have done all this the phone might possibly work correctly again.
Here is a link to a screen replacement video that may help.
Replacement screens are available online. Search for Huawei Mate 20 lite display to find suppliers that suit you best.
If this process seems too daunting, take your phone to a reputable, professional phone repair service, which also does liquid damage repair and ask for a quote for a repair. If you decide to do this, do it sooner than later.
Оценка 1
Добавьте свой ответ
Daisy Higgins будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 0
За последние 30 дней: 2
За всё время: 97
